Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (baldeagle, Wally / Montana, EchoBravoSierra, JW51, 1 invisible), 60 guests, and 2 robots.
Topics128,006
Posts1,055,267
Members48,418
#1108133 06/14/2015 3:52 AM
How do you install a new grill on a 52
dbum
dbum #1108156 06/14/2015 5:38 AM
dbum #1108186 06/14/2015 2:02 PM
As the directions above read, you loosen everything up first, then as those of us who have won this battle will tell you fit everything loose, don't tighten anything until you have all bolts and screws in. It will seem like it will never fit but it does if you leave it all loose. Get a set of good drift pins for alignment and pressure also several screwdrivers as you will quickly use up all the drifts.
https://www.flickr.com/photos/advance-design_parts_co/18772877171/in/album-72157631867396207/
dbum #1108313 06/15/2015 3:13 AM
You can't.
Or so it will seem.
Its hard enough to reinstall an old grille which came on the truck.
An area which can cause a challenge on a reproduction grille is a mismatch in contour at the top corners.
Carl
dbum #1108317 06/15/2015 3:28 AM
Thank you for the advice. Guess I need to buy a shop Manuel. I have the entire front end off of the truck. I assembled inter fenders, fenders, gravel pan and radiator support before attempting to install the grill. Is that the correct sequence?
dbum
dbum #1108323 06/15/2015 4:11 AM
You can not beat a hard copy of a shop manual for working things.
But while your searching try this link and see if something might help.
http://chevy.oldcarmanualproject.com/
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
dbum #1108327 06/15/2015 4:36 AM
The 1952 "Shop Manual" was a supplement manual (to the 1948-51 Shop Manual I linked-to in a post above - that 48-51 manual is hosted by chevy.oldcarmanualproject.com). I do not think the 1952 Supplement Manual is on-line, but maybe someone knows where one is online?
dbum #1108354 06/15/2015 12:19 PM
Thank you for the advice. Guess. Where is a good place to get a shop Manuel. I have the entire front end off of the truck. I assembled inter fenders, fenders, gravel pan and radiator support before attempting to install the grill. Is that the correct sequence?
dbum
dbum #1108355 06/15/2015 12:27 PM
Reproduction Shop Manuals are sold by many parts companies. They are also readily available on eBay (used and reproduction).
There is a reproduction manual that is for 48-51 and includes a 1952 supplement.
http://www.classicparts.com/1947-53-Shop-Manual-Chevrolet/productinfo/04-009/#.VX62a-dHdew
dbum #1108558 06/16/2015 3:45 AM
The grille for the 52 is the same as the earlier ADs.
When installing any of the front end parts (including grille), you need to loosen most of the adjoining parts. This front clip must be adjusted as a unit. It is very difficult to just slap in one of these components and have it go right in.
Carl
