2 members (TexasJim50, Joe W),
38
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | My 1956 has a 265 engine in it. It's not the original engine and whoever pit it in did a hack job making the gas pedal work. Are these pretty good motors? Would it be worth the trouble to make everything right and use this motor? Thanks. Bart | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | 265's were notorious for piston failures. The skirt would crack away from the invar strut that limited expansion from heat, and produce a knock at idle and part throttle. Unless you're doing a period-correct restoration or have some other reason to retain an "original" engine, a later model, larger engine such as a 283 or a 305 would probably be a better choice. Virtually all the small block V8's from the late 50's through the early 90's would be a bolt-in swap with the 265. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can buy the linkage assembly for a v-8 from most specialty suppliers. Classic Parts has it. It is a lot harder to put in with the engine already in. Those were basically good engines but being this old would depend on a lot of things. These trucks run great with the small V-8 in them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2014 Posts: 140 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 140 | I had a 1956 chevy 210 when I was a teenager with a 265. That was one tough little motor let me tell you. Considering the age of the motor it would probably need boring. New replacement pistons with a quality bore job should eliminate any piston skirt issues.I would not be afraid of this engine at all. Just my 2 cents. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I agree with John L. I had a 56 Bel Air with a 265 powerpak. Dual exhaust, 4 barrel Carter. It was a great running engine. Never gave me problems.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Not me, but my brother had 265 in his convertible. We couldn't afford the machine shop work so we rebuilt it "in the sand" under a big oak tree. That sucker, for its time, ran like a scalded dog. Don't remember what happened to it later on but I do remember he had it a long time and he ran it hard.....then we moved on to 283's for the 55's and 57's we had. | | |
