| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Got all the fuzzes in which was easy, then come the window easy again, but the vent window frame, what a pain in the butt. It took me 2 hours and a lot of blue air and paint scraped off and still not in. A friend happened by and it took the 2 of us another hour just to get it in and the glass in the track. After he left I worked another 1/2 hour just to get everything to line up. Is there a secret to getting the vent frame in or is it just a pain? 53 3100 root | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don't feel bad. I had to pull my vent out several times due to window cut wrong, skinned the paint off the vent frame and list goes on. It is a PAIN but so help me, after about 4 or 5 times I could slide that sucker down in there and get it in the channel no sweat. I would advise taking your time and maybe talking to yourself a little along the way. You can do it.......your are putting the window in first and then the vent window aren't you? | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Yes Iam putting the window in first. The drivers side went in easy, first I used some foam rubber i had and centered the window in the door frame then i started the vent frame in the door, lining up the channel with the window. Keeping the window in the vent channel and the rest just fell in place. Boy, just lucky. Now i may have to pull it out again because the vent window handle came off. anyone have a fix so i don't have to pull it again? 53 3100 root | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | root, you should be able to fix the vent window HANDLE with out pulling the assembly. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | The stud that the handle fits on is what pulled out of the frame. I thought about JB weld, but it would be under tension and not compression, so I don't think that it would work. I'am thinking about trying to tack it with MIG. I will protect the truck and the glass with alum.tape and cardboard. Also will tape some copper next to the welding area and hope not to crack the glass. Has anybody done this before? 53 3100 root | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Surely someone would have a vent window if you post in the Parts Wanted Forum. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I have a friend that has 2 of them, but you have to take the vent frame out to change the the wing window, because of the spring and washers or shims that are under it, than the glass. root | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I migged the pivot post in mine but while it was out of the truck not while installed. Once you get the hang of the sequence the windows aren't that bad to R&R. I learned by repeated efforts repeating themselves.
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Well I pulled the trigger, migged the post in with the glass installed, glass still good. Ground, filed, sanded and painted. Tomorrow I will install the handle, back in business. Thanks for all the input, this sight rocks. 53 3100 root | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Best layed plans of mice and men. It broke after the 3rd opening. So it looks like I'am going to have to remove it. S__T Going to take out to friend place and try to tigg it. root
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | If it broke out of the hole in the frame, I'd pull the glass and tack on the inside, Did that way 35, 40 years ago when the glass shop I worked at had several fleet accounts. The drivers would run the CB coax through the vent and spring or break the handle pivot. We brazed them then. John | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Tigged it, open and closed about 30 times, then reinstalled the frame,good to go. root | | |
