1 members (Shade Baby), 58 guests, and 5 robots.
Topics128,271
Posts1,058,314
Members48,485
#1107981 06/13/2015 2:57 AM
7
7 Offline
A few years ago I owned a 51 pick up with a late 50s 6 in it. The valves were noisy so after fully warming it up I pulled off the valve cover and laid some card board in its place to keep oil from spilling out. I then started up motor and starting from front to back loosening tappets one at a time until I heard the loud clicking then I tightened it down until noise stopped. I then went a additional 1/4 turn tighter and moved onto next one. Well the motor was quiet and ran good.
I now have an original 50 216 chevrolet. Any thoughts on the above procedure for this motor?
Thanks John.
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
Riding in the Passing Lane
235 engines with power glide had hydraulic lifters. That is the correct procedure for adjusting the valves. The 216 & manual trans. models had solid lifters. You have to adjust the valves on these with a feeler gauge to the specified clearance.
1972 Chevy c10 Cheyenne Super
Gas Pumper
Gas Pumper
Its almost funny how easy it is to adjust valves once you understand how it works. If you mark the flywheel for 1/6, 2/5, 3/4 it is even easier. For 1/6 for example, when they are both at the top of their travel, one set of lifters will rock back and forth when you move it off center less than 20 degrees. The other set will just sit there and not move. Thats because that set of lifters is at the back of the cam lobe and the one that's rocking is at the top of the lobe. You want to adjust the one that's NOT rocking. Then you can move 120 degrees and do the next set. It took me about 20 minutes to do my engine today. All because of Jeff Pohlar's writeup halfway through this article:
http://devestechnet.com/Home/ValveAdjust
Some people have the knack of being able to explain things so everyone understands. I wish I were one of them. Thanks Jeff!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
