0 members (),
94
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | A few years ago I owned a 51 pick up with a late 50s 6 in it. The valves were noisy so after fully warming it up I pulled off the valve cover and laid some card board in its place to keep oil from spilling out. I then started up motor and starting from front to back loosening tappets one at a time until I heard the loud clicking then I tightened it down until noise stopped. I then went a additional 1/4 turn tighter and moved onto next one. Well the motor was quiet and ran good. I now have an original 50 216 chevrolet. Any thoughts on the above procedure for this motor? Thanks John. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 235 engines with power glide had hydraulic lifters. That is the correct procedure for adjusting the valves. The 216 & manual trans. models had solid lifters. You have to adjust the valves on these with a feeler gauge to the specified clearance. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Its almost funny how easy it is to adjust valves once you understand how it works. If you mark the flywheel for 1/6, 2/5, 3/4 it is even easier. For 1/6 for example, when they are both at the top of their travel, one set of lifters will rock back and forth when you move it off center less than 20 degrees. The other set will just sit there and not move. Thats because that set of lifters is at the back of the cam lobe and the one that's rocking is at the top of the lobe. You want to adjust the one that's NOT rocking. Then you can move 120 degrees and do the next set. It took me about 20 minutes to do my engine today. All because of Jeff Pohlar's writeup halfway through this article: http://devestechnet.com/Home/ValveAdjustSome people have the knack of being able to explain things so everyone understands. I wish I were one of them. Thanks Jeff! | | |
