1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#110789 05/17/2003 2:11 PM
Junior Member
Junior Member
I have 54 Chevy Truck. what is the metal piece of hardward on the inside of the door near the inner cowl that holds the rubber trim around the door. The last 6 inches of mine is gone-eaten by rust. This piece seems to be welded in place. If there is such a piece that can be purchased where? what is it called? And does it have to be spot welded in place or can it be riveted?
#110790 05/17/2003 4:43 PM
That sounds like the windlace channel. I've never seen them listed in parts catalogs, since they're supposed to be part of the cab.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#110791 05/17/2003 5:16 PM
Jim Carter used to carry this, I heard though that it has been discontinued. No other vendor carries it that I know of, you probably need to raid a junk yard.
#110792 05/18/2003 6:11 PM
Or check with someone in the swap-meet here on the Stovebolt cool
