1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 36 Junior Member | | Junior Member Joined: Jan 2003 Posts: 36 | I have 54 Chevy Truck. what is the metal piece of hardward on the inside of the door near the inner cowl that holds the rubber trim around the door. The last 6 inches of mine is gone-eaten by rust. This piece seems to be welded in place. If there is such a piece that can be purchased where? what is it called? And does it have to be spot welded in place or can it be riveted? | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | That sounds like the windlace channel. I've never seen them listed in parts catalogs, since they're supposed to be part of the cab. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Jim Carter used to carry this, I heard though that it has been discontinued. No other vendor carries it that I know of, you probably need to raid a junk yard. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Or check with someone in the swap-meet here on the Stovebolt
