| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Installed front disc brake set on my 52 hotrod build what master cly is a good choice also have ford 9 inch with 2.5 X 11 inch drums in the rear.Do I need residual valves? I would like not to have power just have manual brakes.
Thanks,Pete
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Pete, I know some guys who do NOT run them and some that do. I've never heard either of them complain. I think PirateJack.net recommends a 10 lb residual for the rear and a 2lb for the front running the set up you have.
I am running all drum on my panel but I still put a 10lb residual on the line to the rear. Its suppose to help overcome the springs tension as it keeps some pressure there. I have not had any problems in 2 years and I can stop the panel on a dime and give you 9 cent change!
(Is the steering box going to work for you?) | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Box is mounted,Thanks.Been trying to figure out what master to use.
Pete | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hey Pete I am dumb as dirt when it comes to this stuff but I went to a pre-engineered package I got from Classic car and Performance (CPP) out of the left coast... http://www.classicperform.com/Store/1947_59_Trucks/4954CBK-6HK.htmHere is the link to the kit I bought...quality seems ok...roller bears are Chinese tho..I have not run my truck yet but it was basically a bolt in deal...I am good wrench turner but not a good thinker of new thoughts...saves way more time and problems if you buy these kits...guys on the phones seem pretty decent too.. My smelly old 2 cents... MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | |
