7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP),
111
Mod | | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Have read many times over the years that this 54-55 1st series cross member swap is just the ticket when swapping to a later motor(sloped mounts)in an earlier truck, yes-no? Looking to swap a 250/292 with an automatic in to the old 3600, any ideas would be appreciated.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy JiMerit Boltr#43, yes the crossmember swap allows the proper positioning of the newer engines when using the newer standard transmission bellhousing. I don't think the swap would be of any benefit if you are going to use any automatic transmission other that the four speed Hydramatic, hope that helps. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Thanks guys, that's the one Brad. I was sure some automatics used these sloped type mounts as well? I want to do this swap without loosing the strength that this cross member provides. Maybe I'm overthinking this deal as usual.
| | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | The 52 bell housing should bolt right up to the 54 or later engine so you do not have chance the rear engine mount.
Walt Williams. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Correct Walt, but I'm looking to install the next series 250-292ci engine which used the V8 bellhousing and that will bolt only to a 54 and later crossmember. | | |
