0 members (),
118
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | The front end is in good shape with the hubs and bearings spinning nicely. Rear end turns but the passenger rear brake drum will barely turn; seized to the shoes. Just trying to get an idea of what they are worth. And not sure of the gearing. I also have the front leafs that i took off.
thanks
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If that's a GMC, wouldn't that be a series 150 rather than a 3600, which would indicate that it's a Chevrolet? It's worth trying to find someone that will come over and haul it away, to save you the trouble of making a trip to the scrap yard. There are so many of these trucks that have been upgraded to modern rear axles and independent front suspension that they are a dime a dozen with a little asking around. If you are lucky you may find some off road guy that would take the rear axle. The the only parts of the front end that my be of interest to someone would be the drums, that is if they were not shot. Sorry, I know you might have thought you had a nugget but they're just boat anchors unless you get real lucky and find the right guy.
You will probably have the same problem with the 228 if you're replacing it, which if you're up grading the suspension, I can only assume you would be doing the power plant also.
dg
Denny G Sandwich, IL
| | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | "If that's a GMC, wouldn't that be a series 150 rather than a 3600, which would indicate that it's a Chevrolet?"
Well im sure sure what you are talking about on this. The truck is a GMC and its a 3600 as indicated on the side of the hood and it being a 3/4 ton truck. So yeah im sure its not a Chevy.
"It's worth trying to find someone that will come over and haul it away, to save you the trouble of making a trip to the scrap yard."
I like putting money back in my pocket so ill take it in if no one wants it.
"There are so many of these trucks that have been upgraded to modern rear axles and independent front suspension that they are a dime a dozen with a little asking around. If you are lucky you may find some off road guy that would take the rear axle. The the only parts of the front end that my be of interest to someone would be the drums, that is if they were not shot. Sorry, I know you might have thought you had a nugget but they're just boat anchors unless you get real lucky and find the right guy."
No i dont think I have a nugget just wanting some advice on what they might be selling for.
"You will probably have the same problem with the 228 if you're replacing it, which if you're up grading the suspension, I can only assume you would be doing the power plant also."
dg
No im not selling the motor and tranny, im donating it to a local high school for their automotive class. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Denny was just being nice... its worth what you'll get for scrap.
| | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | Thank you for the info. Denny was just being nice... its worth what you'll get for scrap. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | RGG, Some clarification: Thread title: "'51 3600 GMC" Denny's statement of fact: "If that's a GMC, wouldn't that be a series 150 rather than a 3600, which would indicate that it's a Chevrolet?" Your statement of fact: "The truck is a GMC and its a 3600 as indicated on the side of the hood and it being a 3/4 ton truck. So yeah im sure its not a Chevy." Most likely you have a Chevrolet hood and side-emblems; or, you have a GMC hood with Chevrolet side-emblems. What does the emblem on the front of the hood look like? As you most likely know, the 1951 Chevrolet truck grill looks like this, and the 1951 GMC grill looks like this. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The front brake drums and rear brake drums might be worth more that scrap, if they are in good shape.
The front spindles/knuckles might be worth more than scrap, if the king-pin bushing journals (not the bushings) are not wallowed out. | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Front axle is good for the rat rod gang or maybe the vintage stock car guys to have for their next project...rear axle maybe try and sell the drums and backing plates to someone doing a restore...I scrapped my 3800 rear end...I did keep the front axle...not sure why but I did...
whats the stuff worth???..gosh whatever you can get for them...craiglist ad and see what they sell for...
my 2 cents
mikeC
1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | The grill looks like the 51 GMC and i stand corrected on the side emblem. It wasnt a 3600 it is the gmc with the red stripe underneath. Thanks for the clarification RGG, Some clarification: Thread title: "'51 3600 GMC" Denny's statement of fact: "If that's a GMC, wouldn't that be a series 150 rather than a 3600, which would indicate that it's a Chevrolet?" Your statement of fact: "The truck is a GMC and its a 3600 as indicated on the side of the hood and it being a 3/4 ton truck. So yeah im sure its not a Chevy." Most likely you have a Chevrolet hood and side-emblems; or, you have a GMC hood with Chevrolet side-emblems. What does the emblem on the front of the hood look like? As you most likely know, the 1951 Chevrolet truck grill looks like this, and the 1951 GMC grill looks like this. | | |
