0 members (),
166
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | Early in my search for a proper steering wheel for my 39, I picked up this wheel. I thought it was correct for 39/40 but I don't think so now. The casting looks identical, but the core is different. The hub is much deeper that the wheels I have picked up since then. It also has no splines, only a keyway. Can anyone positively ID this wheel? I'd like to sell it but I want to be sure I know what it's for because I don't want the buyer to go through the same thing I am now. There are three photos at the following link. Thanks! http://i300.photobucket.com/albums/...el/2015-06-07%2009.18.57_zpsd5i2miu2.jpg
1956 GMC 100 NAPCO Deluxe 1955.1 Chevy 3600 NAPCO 1954 Chevy 3600 NAPCO
| | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Looks like a 46 pickup steering wheel. I am not an "expert" but maybe comparing to one from that year will head you down a good path.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | I have what I believe is a 41 (please correct me if I'm wrong) wheel, and it is very different from this type. You can see it in the following link. Notice it has a recess in the bottom for the cast collar hub that fits there, as well as the three large holes for the collar prongs. http://s300.photobucket.com/user/vf...8.25_zpsmz3mh2xl.jpg.html?sort=3&o=1
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Your first set of pictures looks just like what goes on my '37. I don't know what other vehicles it would fit. I am just learning this stuff myself. The last picture is just like my '42, which came off a '41, so if would fit those two years. Probably same up to early '47 (art deco) but again don't know for sure. | | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | Thanks for that... I have my suspicions that it'd be for approximately 31-38... Hopefully someone will know for sure. It's in need of relatively minimal restoration work compared to most of these wheels, so someone is going to be happy to get it.
As far as the second wheel, I think there is a technical difference in the 41 wheel and the 42-46 wheels, but supposedly they do interchange. From the few pictures I have seen, the reproductions are based on the later style wheel which has a deeper steel hub than the one in my second link.
