7 members (GMCJammer51, walter74, JW51, 3B, J Lucas, Joe H, 1 invisible),
85
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 12 New Guy | | New Guy Joined: Jun 2005 Posts: 12 | Will a 1956 Chevy 235 fit in a 1930 Chevy tudor sedan? And if not what has to be done to make it fit? Will the 1930 Chevy transmission and clutch bolt up to the 1956 Chevy 235? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Almost nothing can be used from the 1930 207.
I put a 1954 235 in a 1929 a few years back and here is what I used.
*1937-39 truck 3 speed. *1938-46 truck bellhousing. *1938-53 flywheel and clutch. *1936-46 big truck clutch/brake pivot mount. *modified 19 tooth speedo driven gear.
Your 1956 engine will have the longer lower water pump so that will need attention. I would recommend my water pump adapter for this problem.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2015 Posts: 1 Moderated | | Moderated Joined: Mar 2015 Posts: 1 | I'm considering this swap in my 1929. Does the torque tube bolt right up to the trans without modification? Did you use side engine mounts or is there a way to modify the 235 for front mount? Thanks, -dave
