| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I would like to keep my stock column.I saw an "how to" on cutting it and putting a bearing on the bottom of the column to install the joints and D bar to the box but now I cant find it.Need to see it so I can order the parts and cut the column the right size.
Thanks,Pete | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I am in the process of the same mod (thanks to help from Alvin!), and would suggest that you wait until you have completely installed the engine/transmission (especially the exhaust manifold), and the cab before you cut the original column to the final length. I want to leave as much of the original mast as I can while not interfering with anything on the engine. I cut my mast off close to the original cast piece which bolts to the old steering box for preliminary mockup purposes. Carl
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thanks,Alvin. I've got the engine and trans sitting in there now and I'm doing the mockup,waiting for the headers to come in before I cut the mast.What engine are You installing Carl?
Pete | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | 350 with rams horn exhaust.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Just looked at Rams horn exhaust. I think they will look good on the build.
Pete | | |
