13 members (Bill Hanlon, Oldcaliforniakid, Southerntruck, D B Cooper, Peggy M, Jims46, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 2-Ton, 2 invisible),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | I have a steering wheel on a 55 1st series Chevy that has been wrapped with electrical tape. It must have been done the day it rolled out of the showroom. It is on there to stay. It won't peel off it just breaks off in tiny slivers. Does anybody know a good way to get that stuff off??? thanks mitchell
54 Chevy 5 window - 46 Chevy 1/2 ton
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Iwould start with a hairdryer or heat gun to see if you can soften the tape. Next to that, I would test a solvent like alchohol, to see if it melts the steering wheel rubber/plastic. If not I think that it would work. | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Try WD-40 or something such to reactivate the adhesive that has dried. I would be very cautious using toooo much heat if at all or you will end up with one goooey mess.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Thanks, I'll give those a try. I think one will work. slowgoer
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | If it breaks off like that I'm not sure you will be able to get it off. You might consider useing one of the steering wheel wraps from your local parts house. If thats not going to look like an option, start priceing a new steering wheel. Maybe there not that much. Cecil........ | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is a long shot. Put it in the freezer over night and it may get brittle when cold. | | |
