5 members (Hotrod Lincoln, Otto Skorzeny, HandyAndy, Guitplayer, Hush), 151 guests, and 1 robot.
Topics128,034
Posts1,055,540
Members48,425
#110361 11/18/2004 9:37 PM
I have a steering wheel on a 55 1st series Chevy that has been wrapped with electrical tape. It must have been done the day it rolled out of the showroom. It is on there to stay. It won't peel off it just breaks off in tiny slivers. Does anybody know a good way to get that stuff off??? thanks mitchell
54 Chevy 5 window - 46 Chevy 1/2 ton
#110362 11/18/2004 9:49 PM
Iwould start with a hairdryer or heat gun to see if you can soften the tape. Next to that, I would test a solvent like alchohol, to see if it melts the steering wheel rubber/plastic. If not I think that it would work.
1951 1 Ton Completed
#110363 11/18/2004 10:14 PM
Try WD-40 or something such to reactivate the adhesive that has dried. I would be very cautious using toooo much heat if at all or you will end up with one goooey mess.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#110364 11/19/2004 4:26 PM
Thanks, I'll give those a try. I think one will work. slowgoer
#110365 11/20/2004 2:38 AM
If it breaks off like that I'm not sure you
will be able to get it off. You might consider
useing one of the steering wheel wraps from
your local parts house. If thats not going to
look like an option, start priceing a new
steering wheel. Maybe there not that much.
Cecil........
#110366 11/21/2004 3:44 AM
Here is a long shot. Put it in the freezer over night and it may get brittle when cold.
