1 members (WingWright), 103 guests, and 1 robot.
Topics128,049
Posts1,055,680
#1102729 05/14/2015 11:11 PM
7
7 Offline
I have a 1950 5 window with the 4 speed transmission which has been totally restored by a local shop. The truck has yet to be started as I am doing a restoration.
I have filled it to the proper level with gear lub.
Just from sitting on stands it has developed a oil leak from the drivers side of box.
Do the side cover bolts use seals or should bolt threads
Have sealant. It appears leak is from there.
Any ideas are appreciated.
Thanks John.
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
7998,
There is a gasket on the drivers side of the SM420 4 speed transmission, with if I remember correctly 6 bolts. The gasket needs sealant on it. I use Permatex Copper Spray-A-Gasket on the paper gasket and #2 Permatex Form-A Gasket o the bolts. that should stop your leak. You might just want to check to make sure the bolts are tight...1/4 turn until tight. Don't distort the plate.
Tim
1970 VW Beetle
7
7 Offline
Thanks for info I bet the trans shop neglected to seal bolt threads.
All Original
They definitely need to be sealed:
http://www.pbase.com/dennygraham/image/137528170/large
dg
Denny G
Sandwich, IL
7
7 Offline
Great pic ! Thanks.
The rear diff. is the same through hole design.
All Original
