| | | Forums66 Topics128,051 Posts1,055,711 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | I have a 1950 5 window with the 4 speed transmission which has been totally restored by a local shop. The truck has yet to be started as I am doing a restoration. I have filled it to the proper level with gear lub. Just from sitting on stands it has developed a oil leak from the drivers side of box. Do the side cover bolts use seals or should bolt threads Have sealant. It appears leak is from there. Any ideas are appreciated. Thanks John. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | 7998,
There is a gasket on the drivers side of the SM420 4 speed transmission, with if I remember correctly 6 bolts. The gasket needs sealant on it. I use Permatex Copper Spray-A-Gasket on the paper gasket and #2 Permatex Form-A Gasket o the bolts. that should stop your leak. You might just want to check to make sure the bolts are tight...1/4 turn until tight. Don't distort the plate.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Thanks for info I bet the trans shop neglected to seal bolt threads. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Great pic ! Thanks. The rear diff. is the same through hole design. | | |
