3 members (JeepJoker, Bill Hanlon, Guitplayer), 72 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#1102270 05/12/2015 3:31 PM
....and their proper use. I've been using tin snips off and on for going on 30 years now, and after watching this video learned a thing or two of how I've been doing things wrong...
MPandC #1102428 05/13/2015 4:39 AM
.....as you cut the "filings" will fill up the teeth on the snips. Back when I did ceiling work I got many nice pairs of snips that were thrown away simply because they would not cut. I'd pick them up, run my finger/thumb through the teeth and they would be like new. I hardly ever had to buy a new pair.
Nice video by the way.
MPandC #1102498 05/13/2015 5:02 PM
You got that right Alvin, thought that was my own discovery.
Whenever I cut, I run my thumb over the jaws and a few times
if I'm making a long cut. And, same as you, they cut like new.
I always credited it to the fact that there is a little oil
left on the jaw by my thumb and that was why they cut so nice
afterward.
I still use my first set of Malco snips that I got the first
day of my apprenticeship. The boss took me with him to G. W. Berkheimer's
when he was picking up a furnace and fittings that morning. He
filled up a cardboard box with what tools I would need and
said he'd take a little out of each pay envelope till they
were paid for. I stopped at the local Sears & Roebuck store in
Downers Grove that evening and got a tin box to keep them in.
Still got the box and the original tools also. I have added
some Wiss snipps and other stuff over the years:
http://www.pbase.com/dennygraham/image/160048749/large
dg
Denny G
Sandwich, IL
MPandC #1102592 05/14/2015 3:10 AM
I have never felt so dumb about something which I thought I knew something about. Thanks for sharing it.
Carl
MPandC #1102611 05/14/2015 4:49 AM
I really haven't used snips on about 30 years. We have several of these around the shop. They are quite inexpensive for what they do.
http://www.kett-tool.com/products/detail.php?product_model=KD-440
We use them mostly for cutting .040 tempered aluminum sheets, but they will cut 14 Gauge mild steel easily.
52Carl #1102622 05/14/2015 6:21 AM
Carl
I think learning something new makes you quite smart!
MPandC #1102628 05/14/2015 11:42 AM
U
U Offline
Ken- again, thanks for linking to a tool; y'all have some good equipment! (I'm still looking for the MBX wheel to be (that can be) modified for a bench grinder- something called the 'Berry Amendment' gets in the way sometimes with one of my parts sources ordering one to try out)
Recently -in my particular situation- those electric shears wouldn't have worked due to the radius of the cut out on an fender panel. They'd have been awful nice, but a set of offset left-hand snips did the trick. I do need to watch this video again to make sure it was actually 'left-hand' snips that I used...
Brad
Wrench Fetcher, PhD
MPandC #1102645 05/14/2015 2:36 PM
Had one of these on the truck that belonged to the boss when I
was in the trade. My partner used it all the time, I found
that when cutting only a few holes, by the time he ran the
colds and such, it was dang near as fast to use the hand
tools.
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=1500c
The drill motors converted to shears always seemed kind of
clumsy to me. Might be ok for a straight cut but the geometry
always felt off when cutting shapes.
dg
Denny G
Sandwich, IL
MPandC #1102724 05/14/2015 9:47 PM
Gas Pumper
Gas Pumper
I have the drill motor type like Ken. Use it for many things on these trucks. It turns corners okay, but when I really need a tight radius, I just get out the old Beverly Shear. That is really about the best tool for cutting sheetmetal (sizes less than 3 feet square). That Bosch unit looks interesting. If I didnt have this issue covered so well, I would look into that.
This is the inferior off shoot of an actual Beverly Shear. Yet it works really well! http://www.harborfreight.com/throatless-shear-38413.html
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
MPandC #1102745 05/15/2015 12:52 AM
Denny, Kett makes a shear like Bosch. I bought a used one on eBay several years ago, but its not very often that we use it. I prefer the Kett over the Bosch because so much of the Bosch stuff is made in China these days. Even when you look around at Bosch stuff in Germany, it says made in PRC. Something that I am really proud of is a Fein nibbler that I bought used on eBay. It is like new at 1/3 of the cost of a new one. And it puts our old Miketa nibblers to shame.
MPandC #1102857 05/15/2015 3:03 PM
I don't doubt that Ken, bout everything we find today is made in
the Chin dynasty. Gotta remember, I served my apprenticeship
'68-'72 forty years ago when Bosch was the Cadillac of tools,
also when Cadillac meant quality.
I use a nibbler once in a while cut they make for a lot of
waste and more clean up along the cut. Think the only nibbler
that I've got now is one of those cheap twenty dollar
pneumatic ones from HF, you know, the one that jams up every
time you use it.
Those throatless shears are good for bench work, I'd like to
have one, but then again, I'd like to have one of everything.
Wouldn't mind having a nice Pexto bead roller with all the
dies, an eight foot finger brake, a good four foot shear, a
four foot slip roll. If I still had room in the corner I'd add
a Rotex rotary hand punch and a Roper-Whitney notcher. But
after cutting sheet metal by hand for years, it's my favorite
way of shaping a sheet metal part when I'm in a hurr.
A good set of Wiss pattern snips and my Bull snips
satisfy's
my needs most of the time.
dg
Denny G
Sandwich, IL
MPandC #1102949 05/16/2015 12:26 AM
Gas Pumper
Gas Pumper
I use a system of 1.5 inch holes in strategic legs of tables that use 2 inch legs with 5/32 width, as sort of a telescoping tubing system to allow for all of my bench tools to be interchangeable in these holes all over the shop. The throatless shear sits in a holding area where all of my bench tools sit when not being used. When I need a paint shaker, I put it in a hole, tighten it down, and use it. Same for the shear, extra bench vise, bench grinder, porta band saw, drycut saw, anvil, 4 stage grip cage, whatever I need at the time, I just go get and put in the appropriate hole.
This way, I have versatility in a small area. The Beverly Shear is one of the mainstays. When I am in sheetmetal mode, its the GO TO tool. Its as handy as that Makita grinder thats hanging on the welding bench. Most people just use their tools. I am obsessive when it comes to organizing them for small shop operation. Too cheap to buy stuff I may not use.
Deve
The Think Tank
MPandC #1102975 05/16/2015 2:30 AM
Now that's one good idea Deve, usually you're much to finicky
for me but using a universal mount on anything that is small
enough for an old man to carry from the holding area to the
bench really appeals to me.
My first 20 x 20 garage was much to small even though I did
build a Pitts special in it, then came the 45 x 42 Hanger at
the airport and soon it only had room for the Pitts some new
machines for the machine shop and the Wagabond, so now I'm
into a 42 x 80 building and it's still to small, yep, ya never
have enough room.
dg
Denny G
Sandwich, IL
MPandC #1102983 05/16/2015 2:56 AM
I've outgrown my shop a long time, but I'm gonna make the best of the space I have for the few years I'll be able to supervise truck maintenance. I built a rack for pneumatic tools that we use every day out of angle iron with holes in them.
https://plus.google.com/u/0/1081977...4942505330&oid=108197707187186692269
I keep the more specialized tools in a separate room so that people who don't know how to use them don't ruin them.
MPandC #1102992 05/16/2015 3:18 AM
Gas Pumper
Gas Pumper
http://devestechnet.com/Images/Restorations/1950B/D50b02033lg.jpg
Zoom in. There are three holes across the front (corresponding to the legs). The rack where other things that go there is above the bench. Lots of the other stuff I mentioned is in other holes in the shop. I use a 3/8" plate with 1.5" (x6 inches w/ 5/32 walls) square tube for attaching everything. Thats just one bench. I have six others around the shop and some carts with that hole receiver and bolts for tightening.
Deve
The Think Tank
Deve #1103051 05/16/2015 1:27 PM
U
U Offline
That'd be where the tin snips go! Thanks for the picture; I've been pondering what to do with all 3 of my air tools...
Also Thanks for the picture. I have a POS Harbor freight bar from some 24" squeeze clamps I know how to use now. Should work good for my vice grip storage rack.
Brad
Wrench Fetcher, PhD
MPandC #1103058 05/16/2015 2:31 PM
Not as prolific as your collection Ken, but I'm hanging the
small stuff, the biggies are in the bottom of the box.
http://www.pbase.com/dennygraham/image/160073873
Nice bench Deve, I keep a few of my smaller clamps in a rolling
cart so I can take them where I might need them.
http://www.pbase.com/dennygraham/image/160073874
dg
Denny G
Sandwich, IL
MPandC #1103093 05/16/2015 5:45 PM
Gas Pumper
Gas Pumper
THAT is a nice clamp cart Denny. You can never get enough clamps.
My bench is bolted to the floor and perfectly level. The left side with the tracks in it enable me to clamp things to the table. It really is all about proper clamping.
Deve
The Think Tank
Moderated by  MNSmith
