13 members (Greg_H, KEVINSKI, Gdads51, Bill Hanlon, Otto Skorzeny, greenie-reddy, 1955 1 Series, klhansen, Ponchogl, cmayna, Peggy M, 2 invisible), 121 guests, and 3 robots.
Topics128,266
Posts1,058,385
Members48,485
Re-installed my complete 216 rebuild about 8K back. All new
hoses of course, new stat, flushed and pressure checked
original radiator and heater core. I thought it made sense
to upgrade to the latest GM technology and use the Dex-Cool
that GM has been specifying for the last couple of decades.
As I posted to a buddy this morning, BIG MISTAKE!!!!
Been having little cooing system problems, like little radiator leaks,
heater core leaks, hoses vulcanized to the fittings and this
reddish brown sludge in the radiator.
Just now spent a couple of hours reading all the bad reports
from mechanics and radiator shops about Dex-Cool, and the
class action law suits that are pending.
I wish now that I would have done my ‘homework’ before
choosing Dex-Cool over plain old green EG.
The worst thing was the destruction of the pristine original
fire wall Mariner Blue paint. The radiator was leaking a
tiny bit at the top, just enough that the level only needed
topping off once or twice a year. But….those few drops were
enough that it was blowing back in a spray and the acid in
the Dex-Cool etched itself into the original paint.
Before being sprayed with Dex-Cool or early on:
http://www.pbase.com/dennygraham/image/115111615/large
Last stage at time of repair:
http://www.pbase.com/dennygraham/image/160023893/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ouch... Boy would i be [censored] off!!! Why would the dex-cool contain acid?, I'll stick with regular ol' prestone full green.
Dex-Cool was not intended for use in vehicles with cast iron blocks/heads. It also seems that acids are formed if the system is not completely filled, with no air at all in the radiator. If the system ever overheats, acids are prone to develop due to the chemistry of the coolant at high temperature. Plain old green ethylene glycol is probably the best choice for cast iron engines with copper radiators. Aluminum block/aluminum radiator systems with puke tanks and high-pressure radiator caps that keep the air purged out is what Dex-Cool was designed to be used with, and it seems that idea was only partially successful.
Not claiming to be an expert here, just tryin’ to give a heads up to anyone that might be
thinking about using this stuff in their classic truck. This is just the results that I’ve had
with Dex-Cool.
I do agree with your take 100% on going green Jerry and yes, one of the pro’s is that
Dex-Cool is easy on aluminum parts. And though it may not, have been intended for,
but by some executive order, was used in and recommended for all the GM engines
since 1996. Not all parts on all GM vehicles came with aluminum engines, some cast
iron and some plastics are still being used and vehicles are still delivered with the red
juice installed. My 2014 5.3 liter V8 Silverado does have cast aluminum heads and a
cast aluminum block but….with cast-in iron cylinder liners, so there’s still a lot of cast
iron in contact with the Dex-Cool in many parts of the cooling system.
http://prestone.com/enca/products/antifreeze_coolant/product_list
In my case, the extended life antifreeze, or OAT (organic acid technology) antifreeze
seems to be where the blame lies for the etching of the cowl paint, the culprit I believe is
from the acid, 2-ethylhexanoate in the compound.
My ’50, 216 truck has not been run low on coolant, has not over heated, does not have
a recovery tank and uses a sealed 4lb cap. It is, however rubber, brass and cast, if
that’s a problem. So far the water pump seal hasn’t started to leak and I don’t have any
plastic gaskets. However I am seeing some clotting even with the low mileage that the
engine has on it, that being, under 10K miles.
So, I will be getting’ out the Prestone flush tools and chems and gonna do some serious
clean up before I put a new stat and green goop back in the new set up.
There are literally hundreds of complaints about the damage that’s been caused in
some vehicles. There have also been class action suits filed against GM which they
have settled, that to me is an admission of some guilt.
Here’s one such just randomly grabbed off the net from a few years back:
http://www.stuevesiegel.com/ssh/res...hed-in-gm/dex-cool-class-action-lawsuit/
There are also hundreds of testimonials online from radiator shops all across the
country and ASE certified mechanics as to the problems encountered with Dex-Cool.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Yup, Dex-Cool is nasty stuff. Even for engines it was intended for, eats the gaskets. Lower intake leaks are common on GMs with Dex-Cool in them, especially the 3.8 V6.
Bill Burmeister
OK, the wife's '97 Buick with the 3.8 V6 is going to get a change to Prestone. Dex Cool was specified in the owner's manual and I have added a 50/50 mix of that when needed. I use Prestone in the '48.
On the Buick, make absolutely sure to flush the system out to remove as much of the Dex-cool as you can. When Dex-Cool mixes with old school green antifreeze, nasty things can happen. At best, it'll just sludge up and make a slimy brown mess. At worst, and I have seen this happen, it'll set up link concrete in the cooling passages. If you do change it over, I would suggest using the "mix with any", which is the Chrysler spec HOAT, and is a greenish-gold in color. Much better than Dex-Cool, works fine in old school systems, too. I've been running that in mine without any problems at all.
Bill Burmeister
I have used Preston & distilled water in all my vehicles for many many years and have never had a problem. For me no need to change.
Originally Posted by larryelvick
I have used Preston
I thought he was a Mountie sergeant up in the Yukon!
http://www.westernclippings.com/images/remember/sgtpreston_king.jpg
eeeek
....it may get me in the end but right now the 2000 Silverado has over 282,000 on it and has never had anything but Dex-Cool along with the wife's 06 Buick. Now DG, why did you have to start this thread? I won't get any sleep tonight!!!!!!
I have Dexcool in my 96 truck I've owned since new, and also my 97 Blazer. Haven't had any problems, but I also service the systems regularly. I also believe in what Hotrod Lincoln says, air in the system, or mixed with green anti freeze will cause problems.
Brian
1955.2 3100 Truck
The Silverado has all the right parts in the system to use Dex-cool. Go back to sleep.
Sorry about the rant Jim, thought you were aiming that at me,
I see you were just pullin' Alvins jeber in fun, I apologize.
I've deleted my original reply.
We have had a few guys here recently that are constantly
shooting arrows into the threads just to satisfy their egos
rather than adding constructive comments.
Denny G
Denny G
Sandwich, IL
Wally, Dex cool is the least of the problems on that engine. If you have been adding coolant w/ no leak found they tend to melt the upper intake manifold around the ERG tube from the lower manifold (just behind the throttle body). ERG tube is too close to plastic, melts into coolant passages to throttle body & sucks coolant into intake.
#01-06-01-007C: Engine Coolant Consumption or Coolant Leak (Inspect for Material Degradation/Replace Intake Manifolds) - (Sep 20, 2007)
Subject: Engine Coolant Consumption or Coolant Leak (Inspect For Material Degradation/Replace Intake Manifolds)
Models: 1995-1997 Buick Riviera
1995-1999 Buick LeSabre, Park Avenue
1996-1999 Buick Regal
1998–1999 Chevrolet Lumina, Monte Carlo
1995-1996 Oldsmobile Ninety-Eight
1995-1999 Oldsmobile Eighty-Eight
1998–1999 Oldsmobile Intrigue
1995-1999 Pontiac Bonneville
1997-1999 Pontiac Grand Prix
with 3.8L Engine (VIN K — RPO L36)
also the lower intake gasket to heads is a plastic w/ rubber inserts. Coolant passages @ center of intake (not on ends like SBC) so may not see external coolant leak but leaking into crankcase. Newer gaskets have metal w/ rubber inserts, hold up better. great engines other those 2 items.
BC
1960 C60 pasture art
Is that in any way related to this sort of complaint BC?
dg
Denny G
Sandwich, IL
Gas Pumper
Gas Pumper
http://www.evanscooling.com/questions-and-answers/science-of-evans-coolant/how-it-works/
There is all kinds of hocus pocus out there. Not sure about this one. It was featured in an episode of Powerblock TV.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Don't shove them in the ditch just yet Alvin.
And don't worry, many of us DO recognize and appreciate witty sarcasm when we see it.
Carl
dg
That's a 3.1 / 3.4 they are working on. Intake gaskets have the same plastic issues but the 3.8 vin K (series II) have the upper intake issue as per the bulletin. G.M. redesigned the lower (aluminum) intake in mid 1999 w/ smaller EGR tube so there is a gap between the EGR tube & the plastic intake, seems to have fixed that issue. There are aftermarket repairs for the issue.
BC
Sure was simple back in the day, getting way to complicated
now. I don't envy you wrench twisters these days, way to much
to go wrong, and way to hard to get at anything to work on it.
Just refilled my 216 with clear water to flush out the
Dex-Cool and now the water outlet goose neck is oozing. Didn't
have time before supper to pull it off and see what's
happened to the gasket, did check the bolts and they were
tight. That was all replace roughly 8k back with the engine
rebuild. Dex-Cool???? Don't know yet, but it wouldn't surprise me.
dg
Denny G
Sandwich, IL
I would think the easiest way to change the dex-cool out would be a good drain and flush then refill with Prestone all makes/models/colors. That way if there is a bit of diluted dex-cool left it would be further diluted.
Ed
Moderator, Electrical Bay
This is true. I've had to replace the intake gasket on 3 different occasions. I had to replace it twice on the same engine before I learned my lesson. I avoid it.
Jon
~ Jon
Gas Pumper
Gas Pumper
Has anyone tested the Evans Waterless Coolant?
Deve
The Think Tank
I've heard it causes overheating issues in some vintage engines, particularly Flatheads.
Bill Burmeister
Denny, when did you install Dexcool. It was designed for aluminum blocks, and it has been in litigation for at least 12 years and GM reached settlements in 2008 before their bankruptcy.
I have used Fleetguard 50/50 for over 15 years in everything and have had absolutely no problems with it. I buy it by the 55 gallon drum, but it is available in gallons.
http://www.ryderfleetproducts.com/r...2CuIpB9YLyrE1-bu-lEYe6X7Px9dQaAsiQ8P8HAQ
That would have been about six years ago Ken, when I rebuilt
the engine. Flushed it super good and put the good old green
goop back in.
dg
Denny G
Sandwich, IL
