8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | OK, I admit up front that I am not capable or knowledgable at all about doing body work or painting. I have just finished cleaning and painting my frame but I'm not about to tackle any exterior body parts so they are going to go to a good painter. I do however want to put some protection on the inside of fenders and the bottom of the cab. They are in pretty good shape and clean up well with a wire wheel, so I'm planning on painting them with Chassis Black and not using any undercoat product.
1. Will this be enough protection for my daily driver, assuming that I inspect every few months and touchup?
2. Should I paint the underside before I take them to the bodyshop/painter?
Thanks in advance. | | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | I wouldn't paint the underside before I took it to a painter. Unless he does a very good job of taping off the underside to prevent overspray, you will have overspray on you new underside paint.
Ask me how I know this. I painted the under side of my cab first and forgot to tape it off. Now have some overspray on the bottom I need to take care of. | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Does it matter? Unless it's a show truck I'll bet it looks fine. Not many people are willing to get down on there hands and knees to check out the bottom. I painted the bottom of my cab and then did the top two days later and it looks pretty good. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Two coats of the POR-15 should last a long time, if it's properly applied. However, you should still inspect it occasionally. Overspray shouldn't be a problem. If there is any, it should come off easily, regular paint doesn't stick to POR-15 very well.
Fred 52 3600 69 C-10
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Paint the bottom first. It is better to have overspray on the bottom than on your freshly painted doors etc.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | You could also mask it yourself, before you take it to the painter. Save a little $$$$ that way, too. | | | | | Joined: Nov 2003 Posts: 41 Member | | Member Joined: Nov 2003 Posts: 41 | Paint the frame before you have the paint work done. Itll be easier to touch up the frame than it would be to remove the overspray off your nice new paint. If its going to be a perfect show truck take the body off of the frame if its going to be a driver youll have to clean up the frame from time to time anyways.
Joe K.
1963 Chevy Stepside 350 with 3 on the tree. 1960 Chevy Bel Air 35k original miles 1991 GMC Syclone #1557 1992 GMC Typhoon #0261
