2 members (sron48, Jay R),
96
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11019 12/09/2003 8:53 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | My good friend has a 32 F 3-window coupe street rod with a 350 Chevy/350 Turbo. Cool car but just like thousands more. Anyway, he says it has a Target motor. I don't think he really knows but he thinks it's a GM crate motor, maybe remanufactured, but not as good a quality as other crate motors. I guessed that a crate motor is a new motor that arrives from the manufacturer/seller in a ...crate. I also guess that a Target is a brand of reman or rebuilt motor. Anybody know anything about this? Thanks :p
Professional Novice
#11020 12/09/2003 9:09 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Weren't the crate motors bought thru a Chevy dealership called "target engines"?
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#11021 12/09/2003 10:57 PM | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I believe they are a new motor from GM, its just the generic 350 motor. About 260 HP with headers and four barrel carb. I think they also use the 76cc non vortec heads. I am considering one for my project. I think 300 hp is possible with a cam change. Would probably change heads somewhere down the line also. | | |
#11022 12/10/2003 8:36 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'm thinking the target motors were the new 350 crates that were built in Mexico.
Fred 52 3600 69 C-10
#11023 12/10/2003 5:13 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | In the magazines you see lots of ads from different vendors for new GM "crate" motors and prices vary from 1295 to 4000. I know there must be performance differences, heads, cams, pistons, etc. But I have not ever notices any advertised as a Traget...? Thanks.
Professional Novice
#11024 12/10/2003 5:33 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | I was thinking right or wrong Target was a short block 350 rebuilt engine. The motors in Magazines price ranges is different cubes and different HP, MORE HP, MORE MONEY! A normal 350 can be souped up as far as you want to go. Easily get 340 HP. Our race Motor has 400 + HP with just a few modifications and work by the boys & I. popcorn The Truth is Out There (509 Big Block Chevy 540HP $7'495.95) | | |
#11025 12/10/2003 5:37 PM | | Anonymous Unregistered | | Anonymous Unregistered | "Target Master" motors have been around for years. I remember installing one in the late 80's into a pickup with a buddy of mine. No frills, basic 2bolt main 350 sold through dealerships. I believe they were remanufactured rather than all new. Seems like there were all kinds of Target Master engines from V8's to V6' - you gave the dealer the application and they would pick the right engine from the list of Target Master engines available. | | |
#11026 12/10/2003 10:35 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Ken's response matches my memory of these motors. My '72 Chevy pickup has a Target Master motor in it, and the story on the pickup is that the motor was repaced by a Chevy dealership long ago.
Those motors were pretty cheap and never intended to compete with the performance 'crate' motors you see advertised today. I don't know if you can still buy them or not. My brother put one in a '62 Chevy pickup he owned maybe ten years ago.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#11027 12/11/2003 6:18 AM | Joined: Oct 2003 Posts: 70 Member | | Member Joined: Oct 2003 Posts: 70 | I worked in a Chev dealership when target engines came out. They were new built in Mexico small blocks, no frill replacement for tired small blocks | | |
#11028 12/12/2003 4:00 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Here is some info on crate engines- Sallee Chevrolet | | |
#11029 12/13/2003 12:12 AM | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Target motors are just crate remaned GM motors, nothing special, usually bored just slightly over, I put one in an 85 Olds 88 a while back, the first motor had 250,000 on it and was getting a bit tired.
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
#11030 12/13/2003 12:40 AM | | Anonymous Unregistered | | Anonymous Unregistered | I think Ken is right on this. Goodwrench motors were new GM, never used engines. The Target was both made in Mexico, and I have heard that they were GM re-manufactured engines. When GM replaces engines under warranty they sent these out for re-build, and then were in the pool for replacement. | | |
#11031 12/13/2003 6:33 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Warren is correct and if you look at the back of the block you will find mexico but with little diffrent spelling. Say Meck-e-co and you got it. i have one that came out of a dump truck. After some modifications it sits lovely in my 37 pickup pulling 400HP...what a ride  | | |
#11032 12/14/2003 8:35 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Not sure what its called but I got me one them "Hecho en Mexico" engines in my 64,also I have installed quite a few others. $1300 from local Chevy dealer, brand new from Mexico. Not sure about the quality, but I haven't seen a problem yet, 3 yr 50k warranty! Hard to beat when rebuilders only go 6 months. Brian | | |
#11033 12/19/2003 8:43 AM | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | THE TARGET MOTORS ARE REMANUFACTURED WITH A CORE CHARGE OR TURN ONE IN.
CRATE MOTORS ARE NEW MOTORS, NO CORE FOR IT. 3YR/ 50K WARRENTY IF YOU DON'T OPEN IT UP & MESS WITH IT. IT'S A LONG BLOCK WITH A OIL PAN,TIMING COVER & VALVE COVER'S ON IT. OIL ALREADY IN IT BECAUSE THE FRACTORY RUN'S IT ON A ENGINE DYNO & THEY SET THE VALVE'S YOU CAN GET A 2 OR 4 BOLT MAIN. OLD STYLE OR NEW STYLE 350.
CHEVY DEALER'S HAS A BOOK ABOUT 3/8" THICK, JUST CRATE MOTORS ONLY, STOCK TYPE FROM 160 TO 290 HP
NEXT STEP UP IN CRATE MOTORS FOR POWER 300HP & UP SOME WITH 6 MONTH WARRENTY AND SOME WITH NO WARRENTY.
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | |
