3 members (Otto Skorzeny, MNSmith, tclederman), 73 guests, and 1 robot.
Topics128,052
Posts1,055,718
#11019 12/09/2003 8:53 PM
My good friend has a 32 F 3-window coupe street rod with a 350 Chevy/350 Turbo. Cool car but just like thousands more. Anyway, he says it has a Target motor. I don't think he really knows but he thinks it's a GM crate motor, maybe remanufactured, but not as good a quality as other crate motors. I guessed that a crate motor is a new motor that arrives from the manufacturer/seller in a ...crate. I also guess that a Target is a brand of reman or rebuilt motor. Anybody know anything about this? Thanks :p
Professional Novice
#11020 12/09/2003 9:09 PM
Weren't the crate motors bought thru a Chevy dealership called "target engines"?
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#11021 12/09/2003 10:57 PM
I believe they are a new motor from GM, its just the generic 350 motor. About 260 HP with headers and four barrel carb. I think they also use the 76cc non vortec heads.
I am considering one for my project. I think 300 hp is possible with a cam change. Would probably change heads somewhere down the line also.
#11022 12/10/2003 8:36 AM
I'm thinking the target motors were the new 350 crates that were built in Mexico.
Fred
52 3600
69 C-10
#11023 12/10/2003 5:13 PM
In the magazines you see lots of ads from different vendors for new GM "crate" motors and prices vary from 1295 to 4000. I know there must be performance differences, heads, cams, pistons, etc. But I have not ever notices any advertised as a Traget...? Thanks.
Professional Novice
#11024 12/10/2003 5:33 PM
I was thinking right or wrong Target was a short block 350 rebuilt engine. The motors in Magazines price ranges is different cubes and different HP, MORE HP, MORE MONEY! A normal 350 can be souped up as far as you want to go. Easily get 340 HP. Our race Motor has 400 + HP with just a few modifications and work by the boys & I.
popcorn The Truth is Out There (509 Big Block Chevy 540HP $7'495.95)
#11025 12/10/2003 5:37 PM
Anonymous
Unregistered
Anonymous
Unregistered
"Target Master" motors have been around for years. I remember installing one in the late 80's into a pickup with a buddy of mine. No frills, basic 2bolt main 350 sold through dealerships. I believe they were remanufactured rather than all new. Seems like there were all kinds of Target Master engines from V8's to V6' - you gave the dealer the application and they would pick the right engine from the list of Target Master engines available.
#11026 12/10/2003 10:35 PM
Ken's response matches my memory of these motors. My '72 Chevy pickup has a Target Master motor in it, and the story on the pickup is that the motor was repaced by a Chevy dealership long ago.
Those motors were pretty cheap and never intended to compete with the performance 'crate' motors you see advertised today. I don't know if you can still buy them or not. My brother put one in a '62 Chevy pickup he owned maybe ten years ago.
#11027 12/11/2003 6:18 AM
I worked in a Chev dealership when target engines came out. They were new built in Mexico small blocks, no frill replacement for tired small blocks
#11028 12/12/2003 4:00 AM
Here is some info on crate engines-
Sallee Chevrolet
#11029 12/13/2003 12:12 AM
Target motors are just crate remaned GM motors, nothing special, usually bored just slightly over, I put one in an 85 Olds 88 a while back, the first motor had 250,000 on it and was getting a bit tired.
51 Chevy 1/2 ton-Restored
46 GMC 1 1/2 ton-Farm Fresh
#11030 12/13/2003 12:40 AM
Anonymous
Unregistered
Anonymous
Unregistered
I think Ken is right on this. Goodwrench motors were new GM, never used engines. The Target was both made in Mexico, and I have heard that they were GM re-manufactured engines. When GM replaces engines under warranty they sent these out for re-build, and then were in the pool for replacement.
#11031 12/13/2003 6:33 AM
Warren is correct and if you look at the back of the block you will find mexico but with little diffrent spelling. Say Meck-e-co and you got it. i have one that came out of a dump truck. After some modifications it sits lovely in my 37 pickup pulling 400HP...what a ride smile
#11032 12/14/2003 8:35 PM
Not sure what its called but I got me one them "Hecho en Mexico" engines in my 64,also I have installed quite a few others. $1300 from local Chevy dealer, brand new from Mexico. Not sure about the quality, but I haven't seen a problem yet, 3 yr 50k warranty! Hard to beat when rebuilders only go 6 months. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#11033 12/19/2003 8:43 AM
THE TARGET MOTORS ARE REMANUFACTURED WITH A CORE
CHARGE OR TURN ONE IN.
CRATE MOTORS ARE NEW MOTORS, NO CORE FOR IT.
3YR/ 50K WARRENTY IF YOU DON'T OPEN IT UP & MESS WITH IT. IT'S A LONG BLOCK WITH A OIL PAN,TIMING COVER & VALVE COVER'S ON IT. OIL ALREADY IN IT BECAUSE THE FRACTORY RUN'S IT ON A ENGINE DYNO & THEY SET THE VALVE'S
YOU CAN GET A 2 OR 4 BOLT MAIN.
OLD STYLE OR NEW STYLE 350.
CHEVY DEALER'S HAS A BOOK ABOUT 3/8" THICK, JUST CRATE MOTORS ONLY, STOCK TYPE
FROM 160 TO 290 HP
NEXT STEP UP IN CRATE MOTORS FOR POWER
300HP & UP SOME WITH 6 MONTH WARRENTY
AND SOME WITH NO WARRENTY.
FRAMEUP TRUCKS - 47/55.1ST
STILL PLAYING WITH TRUCKS
