5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
I pulled the left wheel off for the first time today. I wanted to see why my parking brake wasn't working. I figured it was the cables being seized. Come to find out, the cable wasn't connected to anything. There's nothing for the end of the cable to connect to.
The previous owner had put new brake cylinders and shoes on, but it looks like whatever the cable is supposed to connect to is missing. I'll post photos soon to show what I have.
The second issue is that it looks like the axle seal is leaking. Everything was soaked with oil. Is pulling an axle something I can do myself, considering I don't have have a lift or even a garage for that matter?
Thanks for your comments. By the way, I haven't looked at the right side yet to see what awaits me there. Hopefully tomorrow.
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Woah! Bonus! Digging through the box-o-parts that the previous owner gave me, I found two S-shaped pieces that look like they are the parking brake levers. They have the eccentric bolts on them, and look like they're ready to install! I'm going back in tomorrow to see if that's all I need, but I may have caught a break!
1938 Chevy 1/2-ton
Yes, you can pull the axle yourself. Let us know if you get things worked out.
back yard wrench turner
Pulling an axle is a fairly easy job to do.
Put the truck on jack stands, remove the wheels and drums. Take the axle cover off, be sure to have a drip pan under it. There are a couple of clips holding the axles in place. When the clips are removed, the axles will slide out.
You will probably need to replace the oil soaked brake shoes also.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
