2 members (RLB, qside),
55
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 11 New Guy | | New Guy Joined: Nov 2009 Posts: 11 | There's got to be a gastank that will fit under my bed behind axel in the wrecking yard,s10 ,bronco ????? Don't have 500 bucks to buy out of books.Help Gooch man | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I don't know what the width of your frame is, but I think a new Ford Falcon tank is probably affordable and a better option over a vendor tank setup. See post #4 on this link. There are other ideas in that thread too. The Falcon tank runs about $120 new. It's a 16 gallon tank. One source for a Falcon tank.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I did some work on a modified 57 3100 a couple of years ago. The owner said he installed a 65 Mustang tank. It looked like a fairly good fit. He had the fill inside the bed. It's probably the same tank as a Falcon of the same year. Mounting the tank in that location uses up the space for the spare tire.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I used a Suburban/Panel Truck tank which mounts on the passenger side between the frame rail and drive shaft. I routed the filler pipe back to the rear fender behind the rear tire. I've only filled it once, I just got it on the road and other than filling it slow so it doesn't burp back I like it. The TF Sub/Panel tank fits the pickup frame perfect, modified the in-cab straps to work under the truck. I still carry my spare under the bed in the factory location. Mike B  | | |
