6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#1100833 05/04/2015 3:55 PM
There's got to be a gastank that will fit under my bed behind axel in the wrecking yard,s10 ,bronco ????? Don't have 500 bucks to buy out of books.Help Gooch man
I don't know what the width of your frame is, but I think a new Ford Falcon tank is probably affordable and a better option over a vendor tank setup.
See post #4 on this link. There are other ideas in that thread too. The Falcon tank runs about $120 new. It's a 16 gallon tank. One source for a Falcon tank.
R Online: Content
I did some work on a modified 57 3100 a couple of years ago. The owner said he installed a 65 Mustang tank. It looked like a fairly good fit. He had the fill inside the bed. It's probably the same tank as a Falcon of the same year. Mounting the tank in that location uses up the space for the spare tire.
I used a Suburban/Panel Truck tank which mounts on the passenger side between the frame rail and drive shaft. I routed the filler pipe back to the rear fender behind the rear tire. I've only filled it once, I just got it on the road and other than filling it slow so it doesn't burp back I like it. The TF Sub/Panel tank fits the pickup frame perfect, modified the in-cab straps to work under the truck.
I still carry my spare under the bed in the factory location.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
