7 members (Otto Skorzeny, baldeagle, 1955 1 Series, Rusty Rod, dt235sd, Woogeroo, Hotrod Lincoln), 364 guests, and 3 robots.
Topics128,165
Posts1,057,087
Members48,463
#1100384 05/01/2015 4:10 PM
when I was a child my dad had a 63 GMC fleetside shorty. I finally found the right one. Get this, a two owner truck. Still has the Bill of Sale in it. However, The second owner removed and discarded the motor/trans.. TRAGIC! He did put in a 350 long block , full disc brakes, all new suspension front and rear steering ball joints and a TH350 I think.. Does not look like it has ever be hit, just surface rust. Its still in the back of this guys hanger and has been for a while. Looking forward to you guy helping with advice. Thanks for the forum, these things really help.. Dan
Leo Offline
Moderator
Moderator
Welcome Dan, yes it's a shame that he chucked out the engine/trans, but maybe they were wore out. Good that you ended up with it. Be sure to check in here if you need any type of help, that's why we exist. Maybe when you get the hang of it, you can post a few pics. Good luck.
Leo
Welcome to the Bolt, doctordan. You are at the right place. Take a few days to learn your way around. You know, check the tech tips, the links, and FAQ's. Check out the gallery pictures of trucks similar to yours.
Best advice is to post your questions in the most appropriate forums. Engine in Engine Forum, hot rod questions in the Hi Po Forum and so forth, for the best, fastest and most replies. Guys here know their stuff. See you around the garage.
thanks Gents, appreciated! This will be a fun project. Dan
