1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#109979 04/13/2005 11:24 PM
Junior Member
Junior Member
Can someone tell me if acrylic enamel will dry and hold up ok without using hardner/activator? I'm just painting one hubcap and hate to use a can of hardner since hardner does not seem to keep after it has been open.
#109980 04/13/2005 11:47 PM
works for me!
#109981 04/13/2005 11:52 PM
Works just fine just takes a little longer to set up. just keep the area that your painting warm.
DustyG.
1952 Chevy 1.5 ton
1949 Gmc 2 ton flatbed Dump
#109982 04/14/2005 8:21 AM
If you expect the enamel to be resistant to anything like gasoline, road tar, or any sort of solvent then use the hardener. Acrylic enamel is kind of an epoxy and needs hardener for the molecules to cross link and properly set up. If you are having the hardener harden up on you you can buy it in small quantities at your local paint jobber.
Paint & Body Shop moderator
#109983 04/14/2005 3:31 PM
Junior Member
Junior Member
Thanks. This is a hubcap that goes on a sidemounted spare & not subject to any harsh conditions so I'll try it without hardner.
#109984 04/15/2005 4:48 PM
I've been using the same can of dupont hardener for about 15 years off and on without any problems.
Mike Barnes
1950 GMC 1-ton pickup
#109985 05/01/2005 3:23 AM
Tab Offline
Use hardener or you will have to repaint it in a year.
delete my account and pictures
#109986 05/01/2005 4:32 PM
It's not recommended to spray an entire vehicle in ac.enamel w/out hardener, but what you're doing should be just fine. I used to use ac.enamel a lot, but never sprayed it with no hardener, mostly because I was told you can't color sand and buff un-hardened ac.enamel properly, and it won't resist gas, tar, salt etc. like Josiah said.
Keith
If it were easy they'd have grade schoolers doing it!
