1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 13 Junior Member | | Junior Member Joined: Aug 2004 Posts: 13 | Can someone tell me if acrylic enamel will dry and hold up ok without using hardner/activator? I'm just painting one hubcap and hate to use a can of hardner since hardner does not seem to keep after it has been open. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Apr 2005 Posts: 36 New Guy | | New Guy Joined: Apr 2005 Posts: 36 | Works just fine just takes a little longer to set up. just keep the area that your painting warm.
DustyG.
1952 Chevy 1.5 ton 1949 Gmc 2 ton flatbed Dump
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you expect the enamel to be resistant to anything like gasoline, road tar, or any sort of solvent then use the hardener. Acrylic enamel is kind of an epoxy and needs hardener for the molecules to cross link and properly set up. If you are having the hardener harden up on you you can buy it in small quantities at your local paint jobber.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2004 Posts: 13 Junior Member | | Junior Member Joined: Aug 2004 Posts: 13 | Thanks. This is a hubcap that goes on a sidemounted spare & not subject to any harsh conditions so I'll try it without hardner. | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I've been using the same can of dupont hardener for about 15 years off and on without any problems.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Use hardener or you will have to repaint it in a year.
delete my account and pictures
| | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | It's not recommended to spray an entire vehicle in ac.enamel w/out hardener, but what you're doing should be just fine. I used to use ac.enamel a lot, but never sprayed it with no hardener, mostly because I was told you can't color sand and buff un-hardened ac.enamel properly, and it won't resist gas, tar, salt etc. like Josiah said.
Keith If it were easy they'd have grade schoolers doing it! | | |
