3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1099268 04/24/2015 11:27 PM
Starting hearing a grinding noise in the tranny of my 45 1/2 ton?? Noticed it only in 1st and 3 rd. I've parked it, but never been into the tranny, so I'm shut down until the problem is solved. It is a horrible loud grinding type sound. Sounds like metal grinding on metal. Does'nt happen in 1st or R. Need help in a bad kinda way!! PLEASE!
"Life is tough.....it's even tougher if you're stupid" ~ John Wayne
ndrtkr #1099274 04/25/2015 12:15 AM
I would suggest draining it and pulling the cover for a look, sounds like you have lost some teeth or a bearing. If it has failed there are used ones around, you could post and add in the Swap Meet here. Drained they weigh around 130 lbs and are fairly economical to ship on Greyhound if you had to, a lot cheaper than a rebuild most likely.
ndrtkr #1099279 04/25/2015 12:50 AM
Thanks Brad.... Anyone I could send it to for a rebuild??
ndrtkr #1099289 04/25/2015 1:50 AM
I would look for a good local shop, really I think the best bet if it is broken parts would be to secure a replacement. I am unsure about the availability of the older transmission parts. There is a robust parts network and rebuilders for everything SM420 and newer because the off-road guys use them to. You could try giving Novak a call for ideas, they are located in Logan, Utah and I have sold them a ton of cores, Google them.
ndrtkr #1099306 04/25/2015 3:21 AM
3 or 4 speed trans? I've got a crash box 4 speed from a 1946 1 1/2 ton that's not doing anything, in south central Tennessee.
ndrtkr #1099308 04/25/2015 3:29 AM
3 speed Jerry. Thanks though! I'll google Novaks n givem a call
ndrtkr #1099505 04/26/2015 4:10 PM
Riding in the Passing Lane
The sm420 is a 4 speed trans.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #1099669 04/27/2015 12:55 PM
If the sm420 is 4 speed. What's the 3 speed
