1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Ok, what type of screws to use for transmission cover to floor?, 1952, 3100, thanks for any help.
Joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Disagree...I think the originals were countersunk besides being clutch head. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'll check my Suburban and H-M pickup original floor panels tomorrow, Greg.
Was your Hydra-Matic floor panel countersunk, too?
I doubt if I bagged and tagged my original floor-panel screws, but I will look.
| | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | My 52panel had countersunk screws. They were slotted but that don't mean they were original....but I think so. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | FWIW the tranny cover screws on my '38 are slotted flat head machine screws. <CLICK>
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Got up especially to take this picture at 02:00 this morning, thought I posted it, must have been in my dream. But these are the exact replacement screws to the original screws in my 1950, 3600 w/4sp. The cover is not counter sunk for a flat head screw: http://www.pbase.com/dennygraham/image/159800571dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | GMC used the same screws that Denny pictured. I don't own any Chevs, but it appears that GMC and Chev used the same screws. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Denny, can you take a look at your 54 for me? Thanks, G.H.
I think they may have changed that year...still makes me wrong as he was asking about a 52 but makes me at least feel like I am not losing my mind. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I just now got back from a long day on my last week at work.
Do you all now think the 1954 transmission covers were different from earlier transmission covers (I have 1954 3-speed, 4-speed, and Hydra-Matic covers). Should I look tomorrow to see if they had slotted-head "flat-bottom/base" screws or counter-sunk screws?
Did people confirm that 47-53 3-speed & 4-speed covers used counter-sunk screws? And, were they clutch-head?
As usual, I am confused.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I just replace mine on the 53. They were not counter sunk and were rounded clutch head type. Steve | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Must be confusion with what you're gonna do when you don't have to punch the clock next week Tim, congrats by the way. I think what I can take away from this is as Steve posted, not counter sunk up to '53, all truss head clutch drive then '54-'55 were flat head on the floor and truss head on the toe board, both clutch drive. All of these are carried by .Restoration Specialties & Supply Inc. http://www.restorationspecialties.com/ Seems pretty clear unless I'm missing something. dg
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Look away Cletis...Let me add my Congratulations to your last week of work Tim...hope you and the Mrs. have a nice celebration planned.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I guess my remberer isn't a good as it used to be. This thread made me do some checking and while my slot head memory was correct the flat head machine screw wasn't. It seems that slotted oval head is more accurate for the OEM screws on my '38.
| | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | Would it be okay to ask about the same screws in a '37?
Neither Chevs of the 40s or Jim carter have a listing for '37.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Both my original 1954 Chevrolet H-M covers are counter-sunk. My screws were bagged and tagged, but I do not know where I stored my bagged/tagged screws,
All my other 3-speed and 4-speed covers are flat (not counter-sunk) but I do not know if they were 1954 or earlier or after-market.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | [s]double-posted[/s] oops, similar post - a little confusing trying to follow who posted what, when, where?
Last edited by tclederman; 04/21/2015 6:10 PM. Reason: thanks for correction, DADS50
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Different guys
Similar question | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | You all are great, thanks for the pics Denny, I picked up some stainless Phillips for replacement, can't beat it when they're free. | | |
