2 members (Gdads51, 1 invisible), 92 guests, and 0 robots.
Topics128,052
Posts1,055,743
Hey guys on a 49' with the deluxe cab how does one install the chrome trim in the windshield rubber. I've put the window in and can not get the trim strip to go in. Does the trim need to be inserted into the rubber before the window is installed in the cab?
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Yes, the trim much be installed before putting in the windshield.
Practice makes perfect. (sorry, couldn't resist a punch there)
On a bench, put the trim in the rubber specifically made for the deluxe trim, put the glass in the rubber and instal as a unit. You may need some extra hands. I watched a glass man do it solo. I am not a glass man.
Carl
Be careful removing your glass again...and to add to what the others have already mentioned,make sure the trims are fully seated in the rubber before you attempt the install,I usually use a little mild dishsoap solution or glass cleaner in a spray bottle to make sure the chromes seat fully in the rubber..
The little right angled lip MUST be fully seated.
Once you're happy with the fit,you'll know when they're right because when the glasses go in you'll be hard pressed to do anything other than perhaps bend the trims or worse still crack the glass.
It won't hurt to apply some masking tape over the chromes to hold them in situ as you string the windows in.
Like Carl mentions an extra pair of hands will be useful too to follow you round on the outside while you string just to make sure.
More pix on Flickr.
glad I saw this post before I attempted to install
just-a-hacker
'49 3100 before '99
ME TOO!!!
"When I rest, I rust"
1951 3100 5 window w/ '56 235
I wish I had done my homework BEFORE I put the windshield in!
1949 Chevy 3600
Success today! Thanks guys for the help.
1949 Chevy 3600
Glad you got 'er done. thumbs_up
More pix on Flickr.
This is a life saver tip.
