3 members (mason86, Hotrod Lincoln, UtahYork), 61 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#1092567 03/20/2015 5:32 PM
I know I saw a post on how to stop water from coming through the cowl vent (when closed) from getting into the cab. I have a gasket on it but it still leaks. No rusted hole or anything like that. Does anybody have that link or remember what to do? As always, thanks. Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Red 49 Truck #1092601 03/20/2015 8:08 PM
Neverdone
Unregistered
Neverdone
Unregistered
Red
I am guessing you checked the obvious , the drain hole and tube .
How well is it seated , it is possible that it is slightly twisted . You may put something on the rim [ grease / lipstick etc]of the vent and close it tight , open it back up and see if it transfers all the way around
Dan
Red 49 Truck #1092664 03/21/2015 2:07 AM
Red49truck, I don't have the link but on most trucks the cowl vent handle has a spring to keep it closed tight. Does your's have one? Should it?
....and what type of material is your gasket? Had a "rubber" one that leaked because it wasn't soft enough for the vent to seal. I changed to a cork gasket and problem solved as the vent would "sink" done in it and seal it off tight....and my 37 had a spring on it to keep it tight. Not sure about your 49.
Red 49 Truck #1093453 03/24/2015 6:09 PM
I'm not sure about the spring but the gasket is made out of some kind of foam. I'll get a cork gasket and put some light grease around the top and make sure it seals all the way. Thanks everyone for the tips. Steven
Red 49 Truck #1095176 04/02/2015 6:57 PM
As soon as I get the gasket I'll write back.
Red 49 Truck #1096612 04/10/2015 3:33 PM
I have the same problem on a '53 that had body and paint work and have a fairly new replacement rubber gasket. I see that Classic Parts sells both a rubber one or a foam one. Has anyone used both and can say which they prefer? I also note that the new bolts that are being used to secure the hinges are fairly small and it looks like they should be larger based on the holes. Does anyone have an original to tell me the correct size?
John Hill
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
