1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | '59 nut & bolt restoration I installed two new hinges to the firewall/inner fender. Expected that once installed the hinges would pivot even w/o the hood installed but they don't. I used a block of wood and hammer on the top (hood) surface of the hinge and still get no movement. It's like the hood half of the hinge hits some obstruction on the fender half so that the gears won't move through each other.
So I wondered: "Do the springs have to be installed in order to release the hinge to pivot? Let's try that."
How in the world does one install the springs?? I watched a couple of YouTube videos, incl. one guy who uses a floor jack to expand the spring, then a jig to block it open. Eh?
So... why won't the hinges rotate? Should the hood go on before the springs? Any other words of wisdom?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | You're sure you have them mounted on the correct side? It IS possible to mount them upside down and backwards.
With the Hood ON and UP, I was able to simply get a bite with a vise grip over a piece of carpet/rag (to minimize scratching) and muscle them into place...
| | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | OK, I just went out and studied things. I have them in correctly but realized I misunderstood how they fold. I was trying to get the top plate that mounts to the hood to come forward and down instead of back and down. doh! Now to work out the springs. Because they're new they are very stiff, and I'm very old and skinny. But I will prevail!
| | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | What I did was: use two ratchet straps one on each end of the spring, used two support posts in my garage. Stretched the springs using the ratchet straps and slid small pieces of wood between each of the coils. These held the spring to the correct length I needed. Once the springs are in place close the hood a bit and then remove the wood.
Clem 59 Chevy 3600 New Hampshire
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I saw a video on U-tube where a guy had to lube the pivot points and exercise his new hinges in a vice to get them to move freely. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Anybody remember bumper jacks? One of them modified with a couple of eye bolts or S hooks makes a handy hood spring stretcher, and the wood wedges between the coils will keep them extended long enough to assemble the spring over the hinges. Then lower the hood a little and let the wedges fall out as recommended above. Jerry
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Put the ear of the spring in a vice, and bend the spring to open the coils on one side and put the wedges in. Then bend the spring the other way to put wedges between the coils on the other side.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | Thanks for the tips. I can see the vise method being the easiest. And yes, 57 Stepside, mine also need lubrication.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | On my '59, one of the hinge gears didn't mesh up. With the spring installed, the front arm of the spring was pulled back and actually up against the rear arm. If the gears are not messhed corectly, there could be damage to the hinges. I have several sets of bad hinges.
