1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | A similar topic currently running in the engine department made me question that maybe I need to replace me Cab mount rubber for both Clutch and brake pedal shafts going through the toe plate rub the right side of the openings.
Look in archieves but couldn't find anything about how to replace them. Are these rubbers located at where the cab mounting bolts mount to the frame? How many are there and how difficult to replace?
If having to raise the cab is a requirement then I guess one needs to think about all the heaving items resting on or in the cab which will contribute towards the over all weight. Boy the more I think about all the different item holding the cab down the more my head starts to spin....
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | On my 53 the front cab bolts have a 1/4"x2x2 rubber pad that mounts between the cab and frame. The rear cab mounts are shackles. I don't think replacing the rubber is going to solve your problem, you might try loosing the front cab to frame bolts and see if the cab will shift over a little. Also, it wouldn't hurt to replace the clutch and brake felt seals where they go through the toe plate. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | if its a case of needing to adjust the cab alittle due to the compression of the pads you have I've always used and old fire hose cut up into squares. Most fire depts has some old hose laying around and will give it away...or maybe you know some one who can get it? it has the cloth type outer shell but a very durable rubber inner shell that makes real good body to frame cushions or anywhere you don't want metal to metal. Use one layer or several. Just an idea  | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Craig - it's a snap to replace the one rubber part at each corner - just need to create a minimal amount of extra space to slip the old ones out and new in - all the attached stuff won't hold it back enuff to be a problem - can almost use a long prybar against the frame [suitably padded w/ wood blocks] - loosen all 4 bolts, remove 1, pry up that corner, replace rubber, slip that bolt back in, go to next
Bill | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Today, I looked at the front cab spacers on my truck. Right side seems to have a spacer around 1/4" in thickness. Drivers side???? Only a piece of sheetmetal maybe 1/16" thick, loosely fit. No wonder the clutch pedal shaft, brake pedal shaft and emergency brake pedal shaft all rub towards the passenger side.
What is the correct thickness for this rubber spacer?
| | | | | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | Mine are about 1/4" thick. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | squeeze, 4 bolts? I thought there were just one in each forward corner and a shackle set up in each rear corner. Some where I read on the bolt that there is a 5th mounting area for the cab? If so where is it not that I will even touch it at this point. Looking at the front mounting bolts, it looks much easier to simply cut them out than to try and unloosen them. Are these bolts readily available or can I get something similar at my local Home Depot? The assembly manual says that the clearance between the frame and bottom of cab panel at the front corners should be 1.83" (+.06/-.00). Why don't all of us stop what were doing and go measure our trucks and report back. Nothing else to do, is there?
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Mounting points changed several times during the years. I believe I have seen tech articles on the differences. Also, I believe in the Chevy Duty catalog they have the spacers and I thought even the bolts. I have been planning to fix mine which is leaning to the left.
I also think I saw the location of my mounts mentioned in my shop manual.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Yes, My assembly manual talks about the 2 in front and the 2 shackle setups in the rear. Our main sponsor AC has a complete front and rear kit for around $18. I might be contacting them shortly. After I get my truck up and running (hopefully this next weekend), I'll drive it for a couple weeks and then turn it around, back up into the garage so I can start the front end swap, at which point I will consider replacing these pads, etc. Looking forward to taking a break, so is my family
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Well I measured the space between the frame and bottom side of the cab. Did you guys??? Left side 1.40" -avg Right side 1.81"-avg
So we are talking around .400" difference. Yes another project. Job security.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Ad are the pads you got pretty soft? Just got a cab mounting kit from a supplier which has 1/4 x 2" x 2" pads. They look nice but seem way too soft to me to do the job long term. I have some extra rubber material with casing material impregnated inside which is a lot more firmer that a fellow bolter gave me so I might try it instead. Where does the metal square spacer to in reference to the rubber spacer?
| | | | | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | cmayna, mine are very firm, the rubber was on the frame, the spacer and then the cab. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | If I get my truck up and running early this weekend, I'll attempt to replace at least the front rubber, especially the driver's side.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Why not just remove the the pedal rods to replace the felts craig ? If you are goin' to replace the cab mount rubbers make sure you keep track of the shims you remove. It is tough to get a cab lined up once it is removed from the frame [ kinda like aligning a hood ].
Its nice to see that Ron is talkin' trucks. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Ilooked at the pads on my truck the other day and the thickness of the pad is abought the same as belts used on a round bale hay bailer belt.Its heavy duty material.I also used it for the shims under the radiator suport.Might be a good option?
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I like to use ore & slag conveyer belt rubber for these applications. We call it "flashing belt" around here. I get it at the local copper mines when they sell their surplus . | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Today, I replaced both front cab rubber spacers. Now my clutch pedal shaft no longer rubs against the cab and sqeaks.
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I've heard of people using hockey pucks with holes drilled in them for the box jack up kits. - Scott
55 1st Chev.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Use pieces cut from old bias ply tire sidewalls. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Whitelightening, That's what I used.
