8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | Hey guys... I've been pluging away on my 59 fleetside looooongbed, getting it ready to ride again. Thing is, I took off the bed a couple years ago, and pretty much forgot about it. Now I'm trying to figure out the most efficiant way to strip it for repainting. It's pretty intimidating looking at all that metal on the longbed fleetside, and I sure don't want to break out the old sander and wire btush...I got my fill of that with the front half of the truck! So any ideas? Dip? Sandblast? For now i think i'm going to build a wooden bed until I figure out what to do. Thanks folks! | | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | I should mention, I'm not doing a restoration, just a functional rebuild. I am trying to avoid taking apart too much...I have the whole bed off, and i'd like to refinish it while keeping it as complete as possible. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | I'd go with media blasting...sorta like sandblasting only they don't use sand. Sand can warp the sheetmetal. Contact a couple of your nearby powder coating operations and ask them who they use for media/sandblasting. They should be able to tell you who can set you up. It probably won't cost you much (yes..I know..a relative term)..while you have the box off, I would take the big plunge and pull the cab too. Powder coating the frame in our area can be done for as little as $200. | | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | thanks for the idea, I'll check it out. | | |
