2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
was the original outside mirror black?
round or rectangle I've seen assembly line pictures of round.
smooth back or stepped back?
thank you
1950 driver's side standard-equipment exterior mirror?
arm and round mirror - black
I have seen smooth and "ribbed" backs (four ribs from the center out - 90 degree "pattern".
Maybe someone has a 1950 GM sales brochure with an illustration.
sorry
yes drivers side outside mirror
american classic has this one
http://www.americanclassic.com/images/MOBR.jpg
dennys has the 4 ribs
http://www.pbase.com/dennygraham/image/139199169
classic parts has a smooth back
lukes appears to be smooth back
http://s160.photobucket.com/user/st...0Stefanovsky/photo4_zpsb25dc4bd.jpg.html
Dennys arm goes straight out
Lukes is tilted up
Just wondering how they came, Kinda like the one Denny has, but not sure if thats aftermarket
thank you
The shape of the driver's side mirror arm changed in 1951, because of the vent window (when opened, it would hit the older arm).
Here is a set of pictures that just may show the back of the mirror better. I added the extension arm late last fall.
http://s160.photobucket.com/user/st...sky/Extension%20mirror?sort=3&page=1
I have to thank fellow 'Bolters Spanky + Brad for making it happen. shake I have yet to actually drive the truck with this new set-up. Some concern exists as to how much wobble may be experienced. I will know once April gets here to Michigan! brrrrr
looks good
I guess the mirror back are smooth and not stepped like the american clasic link above
Speaking of the mirrors, does anyone make the backing support piece for the mirror arm base that is on the inside of the fender? Or if you made one, what did you use?
Drew
Inside the fender?
or
Inside the cowl under the dash?
Those are not the original mirrors on my truck Gus.
They're 5" convex mirrors. The bracket is the original but the
mirror was cracked so when I replace it I used the convex ones.
dg
Denny G
Sandwich, IL
I'm going back to black on my truck
When I went back together with it 5 years ago I got all shiny trim. I found out later that they came black, so I'm going to go with that.
See it n a few trucks and I like the look.
Was placing an order this morning a saw the different style mirrors and was just curious.
Oops. Right Tim. Cowl.
Drew
My '50 original is like the american classic mirror listed above.
Black arm and mirror. Arm sweeps up.
50 3100
72 C20 Cheyenne Super SBC
72 C20 Cheyenne Super BBC
68 El Camino SS
2 Offline
Where can you get the Extension Arms for the mirrors?
My 1951 2 Ton has the brackets on the Fenders, cannot seem to locate the arm and mirrors.
Were fender-mounted mirrors a GM accessory?
Here is a GM driver's side mirror with an extension arm.
2 Ton Phil--
Try posting in the "Parts Wanted" forum here for original Extension Arms. I would be willing to bet that a fellow 'Bolter will come through for you. Best wishes!
LUKE
