Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (66flea, farmallb, EchoBravoSierra, Shaffer's1950, 1 invisible), 60 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#1094123 03/27/2015 7:27 PM
I am trying to fire my '51 Chev panel which, I think, has a 235 ci., engine.
I believe it has had another engine installed somewhere along the line.
Engine number: 000I905F54X
That is a capital "i" after the 3 zeros.
No spark because the spring on the points is broken.
If I knew the year of the engine or the parts number for the
parts, I can go to the parts store. Converted to 12V if that makes
difference.
Any help appreciated.
1 1951 Chev Panel with a 350 small block, automatic tranny.
1 2004 Chev 2500 HD pickup... stock
1 1950 Chev 5 window pickup; 261 c.i. engine, 4 on the floor.
With lots of time and money, any Stovebolt can be restored.
That would be a '54 235. Points for any 235 will work.
BWD A40H orA40V Contact set ($15)
BWD G102A Condenser ($6 )
Orielly's Auto parts
Set Gap at .019"
Ron - - Dusty53
1954 Chevy 3604
Thanks cletis and Dusty.
O'riellys is just down the street.
And thanks for the part numbers too.
Installed a new set of contact points. The engine pretty much fired right up.
Some brief blue smoke... probably because I squirted some Marvel Mystery Oil in each cylinder. Oil pressure was very good. Engine settled down to a nice idle.
Again.... thanks for the help and guidance.
BTW.... in the forty ++ years I messed with old cars, I have never seen a broken spring on a set of contact points. Contacts fryed but never a broken spring.
Strange......
Jerry,
The capitol "i" in your engine serial number is actually the number "one", Chevrolet never used the letter "i" in serial numbers to prevent confusion.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1094289 03/28/2015 5:25 PM
Originally Posted by Mike B
Jerry,
Mike B smile
Mike; I suspected as much. Thanks for the info. The "i" is clearly a capital i
as stamped. Makes me wonder why GM choose that instead of just using
the number 1.
Again, thanks for the info.
They used whatever dies/punches they had available. On the assembly line, they probably did take care to distinguish an "I" from a "1". Most likely, the "O" and "0" dies/punches were also interchanged.
