7 members (JW51, Otto Skorzeny, Joe H, 3800GUY, DaveV, Thom75, 1 invisible),
446
Mod | | | Forums66 Topics128,290 Posts1,058,567 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Ive tried researching to no avail. I know i need a 180 degree but cant seem to find them item specific anywhere? I wondered why my truck was overheating until i pulled thermostat housing and nothing was there. Can someone cross reference maybe something i can get at local parts store? Im not sure on the fitment since i dont have one to go off of.
1964 impala ss 1949 chevy 3100
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Can I use a universal one?
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | Your truck would not overheat because of the lack of a thermostat. | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | I read somewhere that with no thermostat it doesnt keep fuild in the radiator long enough to cool it?
| | | | | Joined: Dec 2012 Posts: 78 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 78 | pking75, what kind of shape is your radiator in? Might need to be serviced. any signs of corrosion? I checked a thermostat oem AcDelco 19114426 180
________________________________________________________ Steve | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | pking75, go back to that post and read the input from Pre '68Dave. Click on his thermostat myth link. | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | For 4.00 ill put one in it anyways and see what happens. Yeah the radiator aint in the best of shape and i already planned on buying an aluminum one.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Not all folks at that link. A thermostat will bring you to running temp faster, which is most likely better for the engine and for more efficient pre-warm-up driving. | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Who cares just purchased a 2 row aluminum radiator off ebay and will add the thermostat since its only 4 bucks. Should be good to go then.
Thanks Guys
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Is your water jacket clean. Does coolant come out when you open the petcock on the block below the manifold to the rear? You should check that out before you put the new radiator in, so you won't send any crud into the new radiator. Carl
