Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 132 guests, and 3 robots.
Topics128,290
Posts1,058,566
Members48,492
Ive tried researching to no avail. I know i need a 180 degree but cant seem to find them item specific anywhere? I wondered why my truck was overheating until i pulled thermostat housing and nothing was there. Can someone cross reference maybe something i can get at local parts store? Im not sure on the fitment since i dont have one to go off of.
1964 impala ss
1949 chevy 3100
Can I use a universal one?
1964 impala ss
1949 chevy 3100
1964 impala ss
1949 chevy 3100
Your truck would not overheat because of the lack of a thermostat.
1951 1 Ton Completed
I read somewhere that with no thermostat it doesnt keep fuild in the radiator long enough to cool it?
1964 impala ss
1949 chevy 3100
1964 impala ss
1949 chevy 3100
pking75, what kind of shape is your radiator in? Might need to be serviced. any signs of corrosion? I checked a thermostat oem AcDelco 19114426 180
________________________________________________________
Steve
pking75,
go back to that post and read the input from Pre '68Dave. Click on his thermostat myth link.
For 4.00 ill put one in it anyways and see what happens. Yeah the radiator aint in the best of shape and i already planned on buying an aluminum one.
1964 impala ss
1949 chevy 3100
Originally Posted by pking75
Not all folks at that link.
A thermostat will bring you to running temp faster, which is most likely better for the engine and for more efficient pre-warm-up driving.
Who cares just purchased a 2 row aluminum radiator off ebay and will add the thermostat since its only 4 bucks. Should be good to go then.
Thanks Guys
1964 impala ss
1949 chevy 3100
Is your water jacket clean. Does coolant come out when you open the petcock on the block below the manifold to the rear? You should check that out before you put the new radiator in, so you won't send any crud into the new radiator.
Carl
