5 members (MickeyP, papas52, dt235sd, GA Boy, dgrinnan), 76 guests, and 1 robot.
Topics128,169
Posts1,057,035
Members48,458
Just checking to see if anyone has had any luck find a source or interchange for inner and/or outer grease seals for the front of '42 - '46 1 1/2 tons.
I will also put this in "Parts Wanted" but had to wonder about any interchange that might do the job as well.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
Did you try your local bearing/gear supplier? part # or OD, ID and thickness will work.
3B Offline
Hy Tango, the seal I found is actually a felt encased in metal the dimensions are I.D 2.063 (2 1/16"), O.D. 3.154, thickness .25 (1/4") part number is National 5756, there was an old C/R part number 20669 that was a rubber lip seal, but it may have been discontinued, hope that helps.
Thanks All --- below is a link to a pic of this rascal. Local parts houses have had no luck interchanging.
'46 1.5 Ton Inner Grease Seal
That is a felt seal in a metal housing. Have found those in period farm tractors.
Take the 2 metal pieces apart and replace the felt. I bought some at the hardware store (not much selection) or the fabric store.
Cut it for a tight fit and oil it lightly when you re assemble it.
3B Offline
Hy Tango, what are the dimensions of that seal/felt you have?
I'll have to get the measurements over the weekend. And good to know the felt can be replaced but one of the pair has the metal pretty well smashed up. If I had something like a press I might be able to straighten it out...but I don't.
Thanks to All and good news --- I found some NOS seals on Ebay and took a chance...they FIT!.
For anyone else shopping for these seals, the original box reads...
NAPA Standard #877
Don't know yet if there is a current interchange avail but at least we now have a somewhat newer number.
Great find and thanks for posting the number.
Just occurred to me...is there a place on the forum where we could permanently post various part & interchange (updated) numbers as they are found? Would be a HUGE asset to both current & future builders. Could create lists based on year, model, part,etc.
Just a thought. Anyone else?
