0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Just checking to see if anyone has had any luck find a source or interchange for inner and/or outer grease seals for the front of '42 - '46 1 1/2 tons.
I will also put this in "Parts Wanted" but had to wonder about any interchange that might do the job as well. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Did you try your local bearing/gear supplier? part # or OD, ID and thickness will work. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tango, the seal I found is actually a felt encased in metal the dimensions are I.D 2.063 (2 1/16"), O.D. 3.154, thickness .25 (1/4") part number is National 5756, there was an old C/R part number 20669 that was a rubber lip seal, but it may have been discontinued, hope that helps. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Thanks All --- below is a link to a pic of this rascal. Local parts houses have had no luck interchanging. '46 1.5 Ton Inner Grease Seal | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | That is a felt seal in a metal housing. Have found those in period farm tractors. Take the 2 metal pieces apart and replace the felt. I bought some at the hardware store (not much selection) or the fabric store. Cut it for a tight fit and oil it lightly when you re assemble it. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tango, what are the dimensions of that seal/felt you have? | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | I'll have to get the measurements over the weekend. And good to know the felt can be replaced but one of the pair has the metal pretty well smashed up. If I had something like a press I might be able to straighten it out...but I don't. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Thanks to All and good news --- I found some NOS seals on Ebay and took a chance...they FIT!.
For anyone else shopping for these seals, the original box reads...
NAPA Standard #877
Don't know yet if there is a current interchange avail but at least we now have a somewhat newer number. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Great find and thanks for posting the number. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Just occurred to me...is there a place on the forum where we could permanently post various part & interchange (updated) numbers as they are found? Would be a HUGE asset to both current & future builders. Could create lists based on year, model, part,etc.
Just a thought. Anyone else? | | |
