| | | Forums66 Topics128,018 Posts1,055,341 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | tried and tried to install the t shaped rubber sweeper in the tract on my 49 door. impossible. it was a soft seal product. should I try another brand.yes I bent the little tab down for access. what to do. thanks guys | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If its the one I think your talking about slide you a flat bladed screw driver down the "track" it goes in and widen it out some. Afterwards you can pinch a few places to tighten it up. You did try Vaseline didn't you?...or liquid dish detergent ect. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Need to get that track cleaned out. I use a small wire brush, brake clean, and use a curved dental tool used for cleaning teeth. It is called a scaler. Talk sweet to your dental hygienist, she should have some old ones which can't be used any more. Just don't talk too sweet. I made that mistake and she ended up marrying me. Carl
| | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | thanks I will try that. yes I soaped it thanks | | |
