4 members (elhippie64, baldeagle, Phak1, 1 invisible), 51 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,420
#1093347 03/24/2015 4:02 AM
tried and tried to install the t shaped rubber sweeper in the tract on my 49 door. impossible. it was a soft seal product. should I try another brand.yes I bent the little tab down for access. what to do. thanks guys
jacksun #1093581 03/25/2015 3:36 AM
If its the one I think your talking about slide you a flat bladed screw driver down the "track" it goes in and widen it out some. Afterwards you can pinch a few places to tighten it up.
You did try Vaseline didn't you?...or liquid dish detergent ect.
jacksun #1093593 03/25/2015 4:22 AM
Need to get that track cleaned out. I use a small wire brush, brake clean, and use a curved dental tool used for cleaning teeth. It is called a scaler. Talk sweet to your dental hygienist, she should have some old ones which can't be used any more. Just don't talk too sweet. I made that mistake and she ended up marrying me.
Carl
Achipmunk #1093776 03/26/2015 1:10 AM
thanks I will try that. yes I soaped it thanks
