I have a Trico "electro-vac" booster pump for my wiper motor mounted on the driver's side firewall in my '48 Chevy 1/2 ton. I would like to also mount a windshield washer unit. Both compete for the same location on the firewall. Can these two accessories run together? If so, recommendations on the mounting locations on the firewall for each accessory are welcomed. If these two units can not cohabitate, I will mount just the windshield washer and look to find a good home for the Trico "electro-vac" and its dash-mounted switch. Thanks.
LUKE
