| | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | My 12v Heater switch looks like the pics from post# 838739 which I helped me wire so thanks DAD50/Gus. https://picasaweb.google.com/103098517476416596131/UntitledAlbum15#5582269469555317746 I think I have a problem with a backwards/bad 3 speed switch. First click right starts the switch on High, then Med then far right is Low. Seems like the first click should be Low - Med -High like most. Does anyone else have this problem? I cannot change the internals on the switch and I think another switch in order. Stress on the squirrel cage is pretty dramatic with a loud “thunk” when started. Any ideas would be appreciated but I will not be ordering this same type of switch if this is "normal" Thanks Kevin - 1952 Chev 235.
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | In all of my trucks (3 have stock switches and one has aftermarket switch)the first click is high (no resistance) and the next two are medium and low fan speed. Based on my limited experience of 4 trucks, I think your switch is normal. I don't know if you can find one to your liking, or not. Kent | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It might go from high to low just to provide enough power to get the fan moving?
| | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Guess it will just be a challenge to listen to. 4 for 4 seems pretty normal and good for me Kent. Thanks for the info. Kevin 1952 1/2ton w/235
52 1/2Ton 235 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I think high to low is pretty standard. Admittedly on my '38 a heater was optional (dealer installed) and many folks went with a rheostat type of switch, as did I. My rheostat starts on high then gradually goes to low as the knob is turned. My defroster switch is the paddle type with two fixed speeds and it starts on high as well.
| | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | On my 1951 3100 it goes "backwards" aswell. even though it's not an original switch. Just old. I guess thats how it was back in the days Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | |
