2 members (J Lucas, lumbersawyer), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#1092398 03/19/2015 8:26 PM
My 12v Heater switch looks like the pics from post# 838739 which I helped me wire so thanks DAD50/Gus.
https://picasaweb.google.com/103098517476416596131/UntitledAlbum15#5582269469555317746
I think I have a problem with a backwards/bad 3 speed switch. First click right starts the switch on High, then Med then far right is Low. Seems like the first click should be Low - Med -High like most. Does anyone else have this problem? I cannot change the internals on the switch and I think another switch in order. Stress on the squirrel cage is pretty dramatic with a loud “thunk” when started. Any ideas would be appreciated but I will not be ordering this same type of switch if this is "normal" Thanks Kevin - 1952 Chev 235.
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235
In all of my trucks (3 have stock switches and one has aftermarket switch)the first click is high (no resistance) and the next two are medium and low fan speed.
Based on my limited experience of 4 trucks, I think your switch is normal. I don't know if you can find one to your liking, or not.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
It might go from high to low just to provide enough power to get the fan moving?
Guess it will just be a challenge to listen to. 4 for 4 seems pretty normal and good for me Kent. Thanks for the info. Kevin 1952 1/2ton w/235
52 1/2Ton 235
Ex Hall Monitor
Ex Hall Monitor
I think high to low is pretty standard. Admittedly on my '38 a heater was optional (dealer installed) and many folks went with a rheostat type of switch, as did I. My rheostat starts on high then gradually goes to low as the knob is turned. My defroster switch is the paddle type with two fixed speeds and it starts on high as well.
On my 1951 3100 it goes "backwards" aswell. even though it's not an original switch. Just old. I guess thats how it was back in the days
Chevrolet 3100
Year: 1951
engine: inline 6 217CI
Transmission: Manual 3-Speed.
12Volt.
