| | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Just wondering what you guys do to clean up the thin trim that goes over the inner door seal on the cab? It is one part that I've not seen any aftermarket providers sell, and they are thin, flimsy, and very easily bent/kinked/messed up. Mine from two cabs are even rusted out down low.
Any suggestions on how to straighten those up pieces of trim? | | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | Are you talking about the 47-early 49 cab windlace retainers?
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I believe so.
the 3/4" wide strip that has two humps on the outside and goes around the perimeter of the door. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I stripped some of my more sensitive pieces with a nylon stripper that HF sells which goes in your drill. They last a long time and don't remove metal, I would suggest going with the piece not across it. Steel wool may also work. Most are gone on the bottom 6" right at the floor where most of them are rotted away as well. | | |
