1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#1083925 02/06/2015 4:21 AM
Anyone know if the 10% discount can be used on line & how ... no code.
Does the order have to be called or faxed in? wink
gracias mucho!
Sir Searchalot
Sir Searchalot
I believe there are several other Companies that offer discounts to Stovebolt also. Inquire to management or moderator for procedure. If there are codes, they are not usually published in posts. I always order online, not fax, not phone.
I generally call in because I always have questions. James always has the answers. You need to tell them that you are a Bolter. 10% on all stock items.
David
1952 Chevy 3100
The code word is Stovebolt on Classic Parts of America (Truck Parts).
Jim Carter will give a discount on a phone order (tell them you are a Stovebolt.com member).
American Classic Truck Parts, just tell them you are a member here.
http://www.stovebolt.com/office/thanks.html
Tim, I edited this because JIM CARTER use to give the discount for donors, but there was no way for them to keep checking who made a donation. They also had a code initially. But after several years, we figured the code had been passed around enough. American Classic Truck Parts and Jim Carter are the only two that I know of that give us a 10% discount.
Last edited by tclederman; 03/09/2015 11:50 PM. Reason: I added a link to Class Parts of America (truck parts)
Thanks Guys,
ACTP told me to place a note in the comment section (ordered online).... I did ...but still didn't get the discount.... talked to the Brit ... he would "see if they could fix it". Didn't get a real warm and fuzzy feeling from my conversation. Balls in their court.
DJ
Never got the "fix it" ...
DJ, they for sure probably won't send you a refund but on your next order ask to speak with him and remind him. I'm sure he can give a good discount, maybe give you a vender discount, on your next order where as he can't give you a refund. Hope all goes well.
Thanks Achip ...
Authorized Pest
Authorized Pest
Oh and believe it or not, we don't get a discount from ACTP when we order. We don't order much ... and we usually forget to mention it. If you don't get it, call and remind them again. The Brit is an okay guy. I think he stays pretty busy with the business end of things. Jim Carter stays busy with helping people with their questions.
Peg
~ Peggy M
1949 Chevrolet 3804
