| | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | Anyone know if the 10% discount can be used on line & how ... no code. Does the order have to be called or faxed in? gracias mucho! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I believe there are several other Companies that offer discounts to Stovebolt also. Inquire to management or moderator for procedure. If there are codes, they are not usually published in posts. I always order online, not fax, not phone.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | I generally call in because I always have questions. James always has the answers. You need to tell them that you are a Bolter. 10% on all stock items. David
1952 Chevy 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The code word is Stovebolt on Classic Parts of America (Truck Parts). Jim Carter will give a discount on a phone order (tell them you are a Stovebolt.com member). American Classic Truck Parts, just tell them you are a member here. http://www.stovebolt.com/office/thanks.htmlTim, I edited this because JIM CARTER use to give the discount for donors, but there was no way for them to keep checking who made a donation. They also had a code initially. But after several years, we figured the code had been passed around enough. American Classic Truck Parts and Jim Carter are the only two that I know of that give us a 10% discount.
Last edited by tclederman; 03/09/2015 11:50 PM. Reason: I added a link to Class Parts of America (truck parts)
| | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | Thanks Guys,
ACTP told me to place a note in the comment section (ordered online).... I did ...but still didn't get the discount.... talked to the Brit ... he would "see if they could fix it". Didn't get a real warm and fuzzy feeling from my conversation. Balls in their court.
DJ | | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | Never got the "fix it" ...
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | DJ, they for sure probably won't send you a refund but on your next order ask to speak with him and remind him. I'm sure he can give a good discount, maybe give you a vender discount, on your next order where as he can't give you a refund. Hope all goes well. | | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | | | | | | Joined: Apr 2004 Posts: 5,076 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,076 | Oh and believe it or not, we don't get a discount from ACTP when we order. We don't order much ... and we usually forget to mention it. If you don't get it, call and remind them again. The Brit is an okay guy. I think he stays pretty busy with the business end of things. Jim Carter stays busy with helping people with their questions.
Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | |
