0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | was the original outside mirror black? round or rectangle I've seen assembly line pictures of round.
smooth back or stepped back?
thank you | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1950 driver's side standard-equipment exterior mirror?
arm and round mirror - black
I have seen smooth and "ribbed" backs (four ribs from the center out - 90 degree "pattern".
Maybe someone has a 1950 GM sales brochure with an illustration.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The shape of the driver's side mirror arm changed in 1951, because of the vent window (when opened, it would hit the older arm).
| | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | Here is a set of pictures that just may show the back of the mirror better. I added the extension arm late last fall. http://s160.photobucket.com/user/st...sky/Extension%20mirror?sort=3&page=1I have to thank fellow 'Bolters Spanky + Brad for making it happen.  I have yet to actually drive the truck with this new set-up. Some concern exists as to how much wobble may be experienced. I will know once April gets here to Michigan!  | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | looks good
I guess the mirror back are smooth and not stepped like the american clasic link above | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Speaking of the mirrors, does anyone make the backing support piece for the mirror arm base that is on the inside of the fender? Or if you made one, what did you use?
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Speaking of the mirrors, does anyone make the backing support piece for the mirror arm base that is on the inside of the fender? Or if you made one, what did you use? Inside the fender? or Inside the cowl under the dash? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Those are not the original mirrors on my truck Gus. They're 5" convex mirrors. The bracket is the original but the mirror was cracked so when I replace it I used the convex ones.
dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks
I'm going back to black on my truck
When I went back together with it 5 years ago I got all shiny trim. I found out later that they came black, so I'm going to go with that.
See it n a few trucks and I like the look.
Was placing an order this morning a saw the different style mirrors and was just curious. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Jan 2015 Posts: 2 New Guy | | New Guy Joined: Jan 2015 Posts: 2 | My '50 original is like the american classic mirror listed above. Black arm and mirror. Arm sweeps up.
50 3100 72 C20 Cheyenne Super SBC 72 C20 Cheyenne Super BBC 68 El Camino SS
| | | | | Joined: Feb 2015 Posts: 15 New Guy | | New Guy Joined: Feb 2015 Posts: 15 | Where can you get the Extension Arms for the mirrors? My 1951 2 Ton has the brackets on the Fenders, cannot seem to locate the arm and mirrors. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | 2 Ton Phil--
Try posting in the "Parts Wanted" forum here for original Extension Arms. I would be willing to bet that a fellow 'Bolter will come through for you. Best wishes!
LUKE | | |
